Snowmobile ski question
Dennis Prince
Topic author - Posts: 404
- First Name: Dennis
- Last Name: Prince
I am building skis for a snowmobile build and I am wondering do the original skis have a skeg down the middle of the bottom? And can I get width and lengh measurements. Thanks, Dennis
myersair
- First Name: Randy
- Last Name: Myers
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe and Sedan 1927 four door
Re: Snowmobile ski question
Yes they do. I have a set and they are about 3/4 wide.
Dennis Prince
- Last Name: Prince
Randy, Thanks for the answer on the skis, does the skeg run the entire length of the ski? Dennis
Dennis Prince
- Last Name: Prince
Thank you Joe for the picture that answers that question. Dennis
KBurket
- First Name: K
- Last Name: Burket
Here’s an old post with a drawing with dimensions.
http://www.mtfca.com/discus/messages/59 ... 1480825339
Keep us posted on how your skis turn out.
Dennis Prince
- Last Name: Prince
Thanks for the links, I will let you know what I end up with. Dennis
Dennis Prince
- Last Name: Prince
I finally got my skis finished. They are made out of things out of my raw materials pile (formerly known as a scrap pile) I used wheels that were no good for tires, some broken Model A springs, old bed frames, chain links off a potato digger and what was part of the kitchen remodel at the Elk's Lodge 25 years ago. The skeg on the under side I made 14 inches long and now all I need is snow to test them out. As you can see from the pictures it is not a traditional T snowmobile, my nephew had these tracks for his side by side and doesn't like them so a friend and I put 2 tracks a piece on our T's. We will see how well they work. The only time in my life that I have ever wanted it to snow.
Joe Reid
- First Name: Joe
- Last Name: Reid
Dennis that turned out really nice. Take some shots out in the snow. Model T’s are light but I wonder about boyancy on top of the snow. This is the 30’s version by ARPS.
Mark Nunn
- Last Name: Nunn
Dennis, I'm preparing to make a wood rim for my steeringwheel. I never considered making one like yours. I like it, but I think that I'll stay with the factory shape.
Rather peculiar use for a rare 1925 steel p/u box.
or there is this pair with the spindles on Facebook;
https://www.facebook.com/groups/2503824 ... 7365101454
Fordwright
- First Name: Greg
- Last Name: Popove
Nowadays, some snowmobile skis have a tungsten carbide rib going down the middle. Expensive, but they don't wear down like regular steel, even the hardened kind.Dennis Prince wrote: ↑Sun Dec 15, 2024 9:39 pmI am building skis for a snowmobile build and I am wondering do the original skis have a skeg down the middle of the bottom? And can I get width and lengh measurements. Thanks, Dennis
Joe Reid
- First Name: Joe
- Last Name: Reid
This is how my Supersnowbird started out. The cab metal is pitted more on the inside than outside. The Model A frame was cut, bent and welded to make it straight for some reason and it came with the 25 T pickup box. The frame cross members are now oak and fiberglassed. That is the reason it has the 25T box.
Joe Reid
- First Name: Joe
- Last Name: Reid
Supersnowbird frame. It is bent parallel behind where the cab sits. ?????? You work with what you got.
Dennis Prince
- Last Name: Prince
Joe, You did a really nice job on your Supersnowbird. With it having no rear fenders I thing that the 25 bed looks better than a Model A bed would, looks like a fun vehicle. Do you have to get in and out of the window with that track setup? I am just waiting for snow, all of my snow is coming pre melted.
Thanks for the tutorial & explanation, Joe !
Joe Reid
- First Name: Joe
- Last Name: Reid
The doors are cut and remanufactured to open over the tracks. Still not too easy to get in.
