Cam bearings
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
* REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
Cam bearings
Post by KenHaverhill » Wed Dec 11, 2024 7:37 pm
Is anyone using the new Cam bearings being supplied by the vendors having issues with fit? I am trying to repair a .030 cam thrust issue .my cam is a new 280 but was installed with used bearings years ago.i purchased a new front cam bearing correct for the cam but am finding it to be out of round enough to not fit into the block.it also is very snug length ways .is it common to have to machine them to fit? Or is there a better option parts wise.thanks in advance
Re: Cam bearings
Post by Steve Jelf » Wed Dec 11, 2024 9:01 pm
I believe a rebuilder I know made a fixture to squeeze them round in a press.
Last Name: Hatch
Re: Cam bearings
Post by Dan Hatch » Wed Dec 11, 2024 9:07 pm
Bearings have to be fitted to the cam. They are not plug and play.
Look into the cam thrust kit for your old bearing. Dan
Re: Cam bearings
Post by Mark Gregush » Thu Dec 12, 2024 12:33 pm
Lang's shows .003 OS and standard. If they are standard, would they still need to be fitted? Maybe the OP got the oversized ones?
Art M
First Name: Art
Last Name: Mirtes
Re: Cam bearings
Post by Art M » Thu Dec 12, 2024 1:32 pm
Eight years ago, I bought new cam bearings. The endplay clearance was ok. But, I had to scrape the babbit to get a proper journal fit. It was somewhat time consuming.
Art Mirtes
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
Re: Cam bearings
Post by KenHaverhill » Sat Dec 14, 2024 9:59 am
The issue isn't bearing to cam fit it's bearing to block. I have seen the die and press pictures to make round again but have no access to anything like that.
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Re: Cam bearings
Post by Gene_French » Sat Dec 14, 2024 10:26 am
Kenneth:
i re-machine the cam bearings by chucking on a mandrel and precision grinding the O.D. on a punch grinding fixture ... most machine shops should be able to do this operation ... this should have been done in the original manufacturing process ... Gene French
Re: Cam bearings
Post by Jerry VanOoteghem » Sat Dec 14, 2024 11:45 am
The last cam bearings I bought fit the block just fine. However, they had more clearance with the camshaft than my original bearings. So, back in the engine with the old bearings...
(It was a new Stipe cam BTW)
Re: Cam bearings
Post by speedytinc » Sat Dec 14, 2024 2:04 pm
A lite squeeze in a press will do it. A vice might work if no press.
Measure the od to confirm where & how much squeeze is needed.
RecklessKelly
Last Name: Maxson
Re: Cam bearings
Post by RecklessKelly » Mon Dec 16, 2024 8:42 am
Can one make an oilite bushing reliner for the old outer cam bearing or would it wear the journal faster?
Re: Cam bearings
Post by Jerry VanOoteghem » Mon Dec 16, 2024 10:04 am
If I were going to try any bronze, it would be just regular bearing bronze, (660). I have never been a big fan of oilite. Besides, since it holds its own oil, oilite is made for areas that don't otherwise get adequate lubrication. Cam bearings should be getting their fair share.
BTW, Models NRS use bronze cam bearings...
Re: Cam bearings
Post by Mark Gregush » Mon Dec 16, 2024 10:29 am
And the Model A didn't have any and ran just ran in the block, but they were larger.
RecklessKelly
Last Name: Maxson
Re: Cam bearings
Post by RecklessKelly » Mon Dec 16, 2024 11:46 am
I was thinking oilite being softer than solid metal, wouldnt wear the journal so much.
Re: Cam bearings
Post by Jerry VanOoteghem » Mon Dec 16, 2024 1:16 pm
I don't find it to be softer. It's a compressed powdered metal, (i.e. sintered). Its granular structure allows for a porosity that holds oil. I feel that since it's made of compressed/compacted grains of bronze, it becomes harder in the production process than regular bronze. (Of course, there's many different grades of bronze as well.) I know some folks use it and like it, so maybe I'm wrong, but my experience with it has not been great.
RecklessKelly
Last Name: Maxson
Re: Cam bearings
Post by RecklessKelly » Mon Dec 16, 2024 3:21 pm
Gotcha on that.
hah
Last Name: hardiman
* REQUIRED* Type and Year of Model Ts owned: 26 coupe
Re: Cam bearings
Post by hah » Tue Dec 17, 2024 10:21 pm
Anyone know the proper OD diameter of a cam bearing? Is the pictured jig exactly the size of the diameter or a few thousands smaller?
Thanks.
Swinz
First Name: Paul
Last Name: Swindell
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring, 1923 Touring
Re: Cam bearings
Post by Swinz » Wed Dec 18, 2024 2:09 am
Mike Bender is the man who made the jig, he has a number of videos on YouTube one of which shows him using it during the cam installation. This web page gives some good information and dimensions.
https://mtfctulsa.com/Tech/cam_bearings.htm
TrentB
First Name: Trent
Last Name: Boggess
Re: Cam bearings
Post by TrentB » Thu Dec 19, 2024 9:45 am
Someone was asking about cam bearing dimensions. This drawing is from The Henry Ford’s website.
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Re: Cam bearings
Post by t-time » Thu Dec 19, 2024 11:46 am
Here is one made from bronze
Re: Cam bearings
Post by speedytinc » Thu Dec 19, 2024 11:58 am
Early versions were solid cast iron. (no Babbitt) I have made some from scratch from cast iron stock without a layer of Babbitt.
Model A's cam runs in the iron block with no bearings.
