What is the correct length for a 23 touring?
What was the original finish on it?
23 speedometer cable
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Re: 23 speedometer cable
If you have a Stewart speedometer and the swivel is placed ahead of the axle, the length is 60", and the finish is black. I hope this helps, Russ Furstnow
big2bird
Topic author - Posts: 719
- First Name: Jeffrey
- Last Name: Hausey
Yes, it does. Thank you.
big2bird
- Last Name: Hausey
I have a 60" and a 66". 60" will go on the car.
What would the 66 be for? Just curious.
RVA23T
- Last Name: C
Back/Mother-in-law seat driver speedo placement
The longer cable may be called for if the speedo drive is mounted on the other side of the car to the speedo. This is sometimes necessary if the swivel joint runs in the opposite direction to normal for a T. Swivels can be LH or RH rotation.
