ball cap orientation
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Fri Jan 03, 2025 12:11 pm
There is a thru hole on babbit portion of the ball cap .
Does orientation Matter ?
Thank you
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: ball cap orientation
Post by big2bird » Fri Jan 03, 2025 12:16 pm
Face up to catch oil.
Post by speedytinc » Fri Jan 03, 2025 12:19 pm
Hole to top.
However........ If you have a transmission trash screen, it dumps A LOT of extra oil right on the 4th main leaking excessive oil into the U-joint, especially if the 4th main is on the loose side of the clearance spec.
