need to have castings made
Tim D
Topic author - Posts: 225
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Looking for a company to cast four cast iron brake shoes not T. Have one casting that is soso but ok for a pattern.
JR Ewing
- First Name: Joshua
- Last Name: Ewing
- * REQUIRED* Type and Year of Model Ts owned: 1918 Ford Model T Roadster, 1936 Ford Pickup (I know, not a T)
Re: need to have castings made
Sand casting or investment?
Joe Bell
- First Name: Joe
- Last Name: Bell
what size are they? I made some patterns years back for a big brass car, still have the patterns, have a local foundry that likes my old junk to parts.
If Joe's source doesn't pan out, you could try Cattail Foundry, in PA. https://goodsstores.com/blogs/a-good-wo ... nnsylvania
https://www.chamberofcommerce.com/busin ... il-foundry
Pat Branigan Wisc
- Last Name: Branigan
- * REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Tomahawk Foundry, Rice Lake Wisconsin.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Looks like you've got three suggestions with this one being in your state. Good Luck.
Joe Bell
- First Name: Joe
- Last Name: Bell
Just remembered these where for a Jackson car
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Tim, IMO the best for what you are needing is Windy Hill Foundry ( https://windyhillfoundry.com/ ). You will need to draw it up and then 3D print what you need. Reach out to Clark and see if he can't make what you need. Text me if you have any questions or wanna talk about this.
frontyboy
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
I put juice brakes on my 1909 Stoddard Dayton. I went to the NAPA store and got a cast iron brake drum catalog. I found the diameter drum I needed. It had cooling fins on the outside and was 1" to deep.
I chucked the drum up and turned the drum down and ended up with the correct diameter for my external brake band. I cut the dept of the drum down to work with my brake bands. I drilled the necessary holes to bolt the drum to the spokes.
The drums were cheap a little bit of lathe time and I saved a lot of money over making patterns and casting the drums. Keep in mind you still have to machine the new cast drums. The drums I used were mid 60's Pontiac Tempo for about $24 each.
Just sayin,
frontyboy
Just sayin,
frontyboy
Tim is looking for brake shoes. It did not take long for auto makers to develop fabricated steel brake shoes. Even 26-7 Ts had steel shoes, albeit with cast ends. It may be easier to fabricate what you want, especially with computer cutting available these days. Casting is not a common practice in workshops, unlike fabrication.
