Weaver tow truck crane
Topic author - Posts: 3384
- Last Name: Morsher
If you have a weaver model t era tow truck crane, I could use a couple of dimensions to help me fix mine up. Tmorsher@icloud.com if you are able to help. Thanks!
- Last Name: House
Re: Weaver tow truck crane
Tim,
Is yours a 2 Ton or 3 Ton Crane? The former was fitted on Model T s and the latter on TT s...
This is the one I have, George
- First Name: Jack
- Last Name: Leonhardt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
Tim,
I have a Weaver Model G 3 ton capacity wrecker boom mounted on my '26 TT --- what dimensions are you looking for?
Jack
Jack
I have Donnie Browns old crane. I could use 1) a couple of photos of this area. 2) dimension of angle iron and aprx length along the edge 3) length of this round rod. 4) a couple of photos and overall length of crank handle so I can carve up a foundry pattern. Post here or email tmorsher@icloud.com mucho gracias!
- Last Name: House
Tim,
You have a 2 ton crane. Should say so on the cast iron data plate. Yours has 2 axles of mechanical advantage and Jack’s 3 Ton is larger and sports 3 axles. Makes a difference in measurements.
- First Name: Joe
- Last Name: Bell
Is the crank handle 1 in square? is so I know where one is.
