Ford use of cotter pin fasteners
Topic author - Posts: 72
- First Name: Bill
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Foredoor
I am currently painting the chassis on my 1912 Foredoor. The chassis fasteners have cotter pinned nuts. I assume that this was done due to the poor and lumpy roads of the time. Did Ford stay with this practice all the way through Model T production? Having restored an A many years ago I do not remember there being so numerous cotter pinned fasteners. What is the history?
- First Name: Mike
- Last Name: Silbert
Re: Ford use of cotter pin fasteners
Ford used cotter pins heavily through 1926.
For the 1927 model year cotter pins were being replaced with lock washers.
Exact transition dates are nominal just like everything Ford.
Critical fasteners stayed with them through the end and beyond.
I assume it was a cost cutting measure since a lock washer is faster, cheaper, easier to install then a cotter pin.
Nothing is more secure than a cotter pin or safety wire, except maybe 100 years of rust.
- Last Name: Humble
My unrestored 23 T has cotter pins made with equal length legs which would make installation more difficult. The assembly line solution in 1923 appears to be to not separate the legs but push them over as if a single pin. The cotter pin shown in the picture is on the right spindle arm. All the cotter pins I can see have been installed this way.
- Last Name: Maxson
That cotter pin looks a little new- electroplated, it could have been replaced and the guy did a cheese job on it. The original ones I find on mine have a dull look to them.
I can never find the exact pin in the hardware store, they are either too small and head could almost go thru the pin hole or I can barely push the next size up into the hole. Could be that they arent made to the old sizing standard or not sold in size incerments that fit the T. They dont have the offset end like they used to. I usually cut down one end if its possible with my snips.
- Last Name: Humble
John,
The cotter pin shown in the picture, as well as all the others on my car, are unplated, unpainted, even leged pins that have been in the car for 100 years.
- First Name: Mike
Here is an article written back in the day describing the 6 sizes of the 95 cotter pins and where they go.
They are 3 different diameters and available from many places.
I usually get a assortment kit and loose most of them when the case pops open
I would give credit if I knew who originally wrote it.
- Last Name: Maxson
Maybe the shine of the flash made it look newish.
- First Name: GeorgeJohn
- Last Name: Drobnock
- * REQUIRED* Type and Year of Model Ts owned: 1922 Coupe but not a doctor's coupe
Of course, the use of baling wire and small finishing nails work too.
- Last Name: Maxson
Sure, whatever you can find in the barn.
Elizabeth's Hairpins
is from Murray Fahnestock. If remember correctly it's pretty accurate, with one or two minor errors.
- Last Name: Codman
I wasn't dressed to crawl under my '27, but it uses cotter pins on the spring shackles and on the bottom steering column support. The weather is crappy outside today, so maybe I will find the time to get under it and see if there are others.
- Last Name: Juhl
Fasteners will loosen on anything that moves. There isn't a single structural fastener on an airplane that doesn't have a self-locking nut, cotter pin or safety wire securing it. Henry used what was available and cheap back in the day.
Here is some of the history, excerpt from a letter to Mr Henry Ford, from a F.H.Briggs, dated Sept 19, 1906. Mr Briggs wrote about some quality issues of his new Ford Model N. One can assume that Henry read this letter, and found ways to fix loose fasteners.....Cotter Pins!
- Last Name: Golden
My uncle was born about 1900 and has his first car, and that was a Ford about 1920.
He bought a new Ford in 1950, and the first thing he did was jack it up, and spend about half a day tightening or try to tighten every nut or bolt he could find.
He seemed a little off his good sense at the time, but now I know why he did it.
He also got his first truck driver's license about 1915 in New York City.
Not long after that, he got his first speeding ticket with that truck for doing 18 MPH in a 14 MPH truck loading area.
What really made him mad was the police officer caught him while riding a bicycle and he did not think the speedometer was that accurate on a bike.
The $8.00 ticket had to be paid by him, and that was almost a full week's pay then.
Bet you are talking about all the cotter pins in the bolts holding the pan to block/hogs head?
None of the cars I work on are points cars, so those locations get lock washers which is what Ford went to later. Besides, I have yet to assemble those parts and have not needed to come back later and give a little snug down after the car had been driven a while.
Don't forget the special cotter pins designed to fit the top irons in 1921-22.
