Hogshead weight
JBog
Topic author - Posts: 301
- First Name: Jason
- Last Name: Bogstie
Hogshead weight
Does anyone know the weight of a cast iron Hogshead?
Re: Hogshead weight
It depends on how many times you have tried to fit it after a band change. They put on weight with each attempt.
Re: Hogshead weight
33.0 lbs. 1925 Transmission Cover with Cover, High Speed Clutch Assembly and No reverse or brake Pedals
32.0 lbs. 1926 Transmission Cover with High Speed Clutch Assembly and No reverse or brake Pedals
