Original Rocky Mountain Brakes
Chuck Hale
First Name: Chuck
Last Name: Hale
* REQUIRED* Type and Year of Model Ts owned: 23 T Speedster
Post by Chuck Hale » Sat Feb 08, 2025 10:03 pm
I have a set of original RM brakes that I wanted to put on my 26 ruxtell rearend. I did not realize that the improved axle doesn't have the bolt at the back of the drum like the earlier cars. I am thinking of fabricating a steel plate to attach to the spring perch bolt and the radius rod bolt. Trying to work with what I have, 26 rear ruxtell and wire Wheels. Thoughts?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Original Rocky Mountain Brakes
Post by Kevin Pharis » Sun Feb 09, 2025 12:31 am
You will find that the ‘26-‘27 brake drum is 1” smaller diameter than the RM drum for the ‘09-‘25 rear end. You could swap drums, but the flat RM drum would interfere with the wire wheels
Chuck Hale
First Name: Chuck
Last Name: Hale
Post by Chuck Hale » Sun Feb 09, 2025 1:53 pm
Thanks, that's what I needed to know. Now I guess I need to post a classified to trade these for the ones I need.
Dennis Prince
Last Name: Prince
Post by Dennis Prince » Sun Feb 09, 2025 2:04 pm
I would test fit the brake bands to your drums, the originals may not have used an extra drum to make the later Rockies work with a small drum. If the bands go most of the way around but not all of the way I would think that you could adapt them to fit.
Post by RajoRacer » Sun Feb 09, 2025 4:47 pm
I might be able to assist you in that endeavor - I'll drop you a note.
Post by Original Smith » Sun Feb 09, 2025 4:54 pm
That bracket you have was made by the successor to Rocky Mountain Machine Products, and is for the small drums, not a 26-7. The new company was called Tractor Train.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Sun Feb 09, 2025 4:54 pm
You don’t say if you have a complete set of original style small drum Rockies, including the over size brake drums. If your set is complete with over size brake bands and drums your two simplest choices are to trade your brakes for the later 1926-27 style AC brakes, or you could change your Ruckstell over to a 1925 small drum axle and use your Rockies. If you are using 1926-27 wire wheels I would stay with the 1926-27 Ruckstell. I would not try to cobble up something to make your Rockies work with your 1926 large drum Ruckstell.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Mon Feb 10, 2025 6:38 pm
Agree button pushed.
Get the 6-7 A/C units.
