Rear fender brackets on a 26 roadster
fordt
Topic author - Posts: 165
- First Name: Rob
- Last Name: Trippet
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
Should one put a washer BETWEEN the bottom (forward) hole of the rear bracket and the frame to make up for the thickness of the fender? The top (rear) hole goes thru the bracket and the fender. Or is the thickness of the fender so negligible that the bracket will just bend enough to pull it up against the frame anyway?
TMiller6
- First Name: Thomas
- Last Name: Miller
Re: Rear fender brackets on a 26 roadster
I did not use washers on my rear fender brackets. Everything bolted up fine.
Tom Miller
