Sediment petcock leaking
LittleTimmy52
First Name: Lucas
Last Name: Milatti
* REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
Board Member Since: 2025
Post by LittleTimmy52 » Sat Feb 15, 2025 9:28 pm
I replaced my sediment Bowl and I reused the old petcock after clearing the blockage on the top of it and the petcock is leaking not from the threads but the actual valve part, the spinning part. how might I be able to fix this? I did though disassemble the petcock valve to clean and uninstall and reinstall it but there was no gasket or anything.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Re: Sediment petcock leaking
Post by LittleTimmy52 » Sat Feb 15, 2025 9:31 pm
Might I add that it also only leaks when the sediment bowl valve is open when I shut the fuel off it quits leaking mind you there's still fuel because if I open the sediment drain valve fuel comes out of the bottom. So it seems it only leaks under a light pressure.
Last Name: Juhl
Post by Oldav8tor » Sun Feb 16, 2025 11:49 am
A common problem. You could try lapping the valve with a fine abrasive (rubbing compound, etc. - google it) - it didn't work for me so I bought a new petcock. An alternative is to remove the valve and replace it with a brass pipe plug. Not original but it does the job. Normal procedure calls for turning the fuel valve off before draining the sediment bulb. With a plug you can turn the fuel off and remove the plug to drain the bowl - more efficient anyway.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sun Feb 16, 2025 12:09 pm
Lap the shut-off valve as previously mentioned and then lubricate it with bar soap.
Post by TXGOAT2 » Sun Feb 16, 2025 1:41 pm
Ivory bar soap.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Sun Feb 16, 2025 2:43 pm
Do not be aggressive with lapping or you’ll screw the pooch & create a bigger leak on & off.
Post by speedytinc » Sun Feb 16, 2025 3:56 pm
Use tooth paste. I found you can go to far with 400 grit lapping compound.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sun Feb 16, 2025 4:06 pm
There is an aircraft product called “EZ Turn” that is fuel resistant, meant to lubricate the turning parts of fuel line valves and petcocks. It will stop minor leaks and seepage.
Get a horse !
Post by RajoRacer » Sun Feb 16, 2025 4:14 pm
I also use EZTurn BUT be careful to use it sparingly - it will block the orifice !
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sun Feb 16, 2025 5:02 pm
Well said Steve !! “A little dab ‘ll do ya !”
Apply a thin film to the “cone” make sure none gets in the orifice of the valve. It keeps the moving part from seizing, and will stop a minor leak. Three years now, mine turn easily and don’t seep.
Get a horse !
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Feb 16, 2025 5:31 pm
Hi Lucas,
I use timesaver to lap the valve & for lubricant I picked up a can of G-363 military grade plug valve grease. I believe EZ-Turn is the same spec.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Sun Feb 16, 2025 5:51 pm
I've lapped several similar fuel valves with timesaver then used EZ turn. They don't leak and turn well. Unfortunately, it only comes in a large 5 oz tube that will take me 5 lifetimes to use. I plan on getting some small bottles (prescription bottles?) and give it to friends on tour. :)
Post by RajoRacer » Sun Feb 16, 2025 8:14 pm
I've done the same Noel - more in a tube than I'll ever use !
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Feb 18, 2025 1:06 am
I picked up this @ a swap meet it's about 1/3 full I will never use it all up but don't know anyone that repairs valves other than me.
