Body data plate numbers
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Thu Feb 27, 2025 8:07 am
Who can stamp the correct style numbers on a repro 14 body data plate? RV did my 11 Touring for historical purpose only, not for vehicle identification, and I looking for someone to do the same for my 14 Runabout. Art
Art Ebeling
First Name: Art
Last Name: Ebeling
Re: Body data plate numbers
Post by Art Ebeling » Fri Feb 28, 2025 7:08 am
No answers to the question of someone stamping a data plate so does anyone know where the correct style number stamps are available for the body data plate?
NY John T
Last Name: Killelea
Post by NY John T » Fri Feb 28, 2025 8:01 am
Dataplates4U can, I believe, do it for you. They did mine for my WW2 jeeps.
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Fri Feb 28, 2025 8:32 am
They do not list Model T data plates and the style of the numbers they show on other Ford Data plates is not close to the correct style.
Post by TRDxB2 » Fri Feb 28, 2025 2:29 pm
The number style has been discussed. I copied many engine numbers to arrive at a set to match
New number stamps aren't a good match. size maters as well
RGould1910
Last Name: Gould
Post by RGould1910 » Fri Feb 28, 2025 3:49 pm
I have what appears to be the same font ans size punches as shown above. They are close to those stamped on my 26 not nowhere close to those uaed on my 10 and 12. Ive never found anything close.
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Fri Feb 28, 2025 4:29 pm
The numbers stamped on the block look nothing like data plate numbers. Here are a couple original data plate pictures from posts on this forum. The new tag is the tag RV Anderson stamped for my 11. Art
Post by DanTreace » Fri Feb 28, 2025 4:36 pm
This older post lists a font type numeral that probably is pretty good match for serial numbers on data patent plates.
https://search.app/WN1AkBhS3c12mtLu6
Here is the font type “ Plantagenet Cherokee” for numerals that match closely to original data plates.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Feb 28, 2025 6:24 pm
Art-
You could take it to a trophy shop of you want the old fashioned font style.
Ford also use a plain type of font. You can buy a set of 1/8" stamps at Harbor Freight for $8.99
-Keith
Post by Allan » Sat Mar 01, 2025 1:04 am
Most original car body plates were brass or aluminium. These are softer and more likely easier to photo etch to "print" the details. It also allows the use of stamps with thicker downstrokes which gives them the old font appearance. Hand stamping numbers rarely have this, especially those used to stamp engine numbers on cast iron. These need a sharp edge to make the impression, not the flat bases as on the ID plates.
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Post by Rod » Sat Mar 01, 2025 8:17 am
I just received my rebuilt engine with a replacement block. I had to change the cast block serial number to match my old block and title. I purchased these stamps which appear to be the correct style snd size.
https://restostamps.com/collections/for ... odel-a-b-t
New stamped block
New stamped block
Post by Wayne Sheldon » Sun Mar 02, 2025 4:38 am
Data plate number stamping ended in the mid 1910s. Block stamping and data plate stamping during the years when both were done was different due to the need for cast iron blocks to be cut by sharp fonts. Data plates using thinner and softer materials could use a more blunt font.
Over the years of production, several minor variations of fonts were used.
