Livingood 4x4 conversion for Model T
Channel1tv
Topic author - Posts: 64
- First Name: Bryan
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1921 Center Door, 1923 Depot Hack. 1915 Rajo Speedster
- Board Member Since: 2008
Has anyone seen one of these Livingood 4x4 conversions for sale?
Would love to buy one, but I suspect they are rare and stupid expensive.
If you find yourself the smartest person in your group of friends, it’s time to find some new friends!
Re: Livingood 4x4 conversion for Model T
I suspect you're right. I think I've seen one, but never any for sale.
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
His grandson had reproduced some of them a few decades? ago. Seems like I remember him being in western lower Michigan. White Cloud/Hart/New Era?
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
I remember seeing one in the San Diego area about 25 years ago. One of our club members had it on his car. However, I don't remember whose car it was.
You could probably more easily build one than find one. Outer ends of an old Jeep axle could be grafted to a T rear axle. Some kind of divorced transfer case could be used, maybe an old Jeep. You might need to split the wishbone to handle the drive/braking stress. Roxor?
Petrah Phyre
- First Name: Sean
- Last Name: Pownall
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
If you build one, make it even more of a challenge and make it out of a ruckstell. I want to see the double handed shifting on that one.
Luxford
- First Name: Peter
- Last Name: Kable
The Livingood 4 wheel drive unit was being built in Grayville PA by his son Jesse Jr Livingood.
I visited him and did an article on the 4 wheel drive unit and got to drive Jesse's speedster equipped with the 4 wheel drive.
The article is in Volume 33 No 5 from 1998.
His address then was PO box 125 Grayville PA 15337 and phone No 412 428 3618. That was over 23 years ago don't know what the situation would be today.
- Last Name: Juhl
I know a couple of guys who have one installed on their cars....neither would consider parting with them.
Dropacent
- Last Name: Morsher
I drove that one pictured a couple hundred feet to the street and back. Got out and told the seller that there was something really seriously wrong with it. He fluffed me off, got in and proceeded to get it stuck in his yard. My elderly father and I pushed him back onto solid ground and both walked away soaking wet.
Perhaps I just drove a lemon, but that took care of my desire for one, forever.
Dropacent
And by the way, that pretty body is white pine assembled with drywall screws. It’s a hundred footer, for sure!
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
This has probably been posted before, but it is a good video showing one in action.
https://www.youtube.com/watch?v=fmHoUKq0sC8
Dropacent
After that video I’m convinced I drove a very poor example. It would not have handled 2” of snow.
Luxford
- First Name: Peter
- Last Name: Kable
The speedster Livingood I drove was nice, I would think if one did not know it was 4 wheel drive you wouldn't have known it.
I drove it through 2"deep snow on grass up and down a fair slope no problem. These pictures were in my files of one being put together for those interested.
Bob Pilkie
- First Name: Bob
- Last Name: Pilkie
- * REQUIRED* Type and Year of Model Ts owned: TT trucks and speedsters.
I have a livingood 4x4 kit I’m putting in a 23 roadster/jitney. I don’t really care how well it works just so cool tho. I’m in Edmonton Alberta
JohnM
I'm very curious, is the transfer case belt driven? And is it full time four wheel, or can you disengage it? Thanks
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
There used to be one at Mount Pleasant on display at the Old Threshers Reunion.
JohnM
Thanks Herb, I should inspect one first hand, seeing is believing.
Luxford
- First Name: Peter
- Last Name: Kable
John, Depending which series Livingood 4 wheel unit it is depends on whether 2 wheel drive can be selected.
The transfer case is chain driven. The later version which had a Warford box installed behind the motor is constant 4 wheel drive.
One sold on the Forum in 2019 viewtopic.php?t=4257
A bit of history https://www.motortrend.com/how-to/129-0 ... dster-4wd/ --
Gotta see this YouTube video of one driving in snow
The reshaped front spring looks problematic to me. Ford steering might be a handful with 4X4 engaged.
Bryant
- First Name: Bryant
- Last Name: Shafer
Are there any good pictures of the steering set up?
One390
- * REQUIRED* Type and Year of Model Ts owned: 25 TT
The patents are out there if you want to get a feel for what Jessie Sr did. The steering is same as he T it in terms of connections/tie rod. He used all model to parts. There are original advertisement out there as well. As someone said the transfer cases are chain driven with simple engagement. Like anything else if it is set up as intended it works fine. If you have something not right you have to fight a second driveline. Trying to compare it to a modern 4x4 is tough at a functional level just like trying to comparison a T engine to a modern 4cylinder. They are very cool with a very neat history and a hard to come by. He used to make them but unless the 3rd generation picks it up there won’t be anymore made.
Angmar
- Last Name: Bailey
I would think that there would be a market for the original conversations if someone took it up again. I certainly would want to have one
Still crankin old iron
I'd love to have one under a late roadster pickup.
More Pictures
still checking out on the internet
724-428-3618
Jesse R Livingood Graysville, age 82, male
104 Stringtown Rd, Graysville, PA 15337
724-428-3618
OilyBill
- First Name: William
- Last Name: May
Research shows he died on November 11, 2023. The obituary says he built a total of 4 of these conversions. He was a very skilled machinist that worked on coal mine equipment for many years. Someone might want to contact the family and see if his drawings still exist for the 4 wheel-drive conversion, and if they would permit them to be used.
If you want to see one, there is a complete and intact example, installed on a Model T, at the Rolling Through Time Auto Museum, in Tucson, Arizona
- First Name: Henry
- Last Name: Lee
The new and improved C.L.S. 4 X 4 conversion is in the making and will start in the winter. Stay tuned for photos and specs!
Will definitely stay tuned.
dobro1956
- First Name: Donnie
- Last Name: Brown
Henry, I'm definatly interested ... staying tuned ...
