Model T magneto Regulator ?
Modeltmike
Last Name: Sleep
* REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 22 center door, 23 touring, 21 touring and 26 Fordson.
Post by Modeltmike » Wed Mar 12, 2025 10:04 pm
Removed this from a car I purchased. Is this used to charge a battery, run lights, or? Was going to throw it on a table at a swap meet, but not sure what it does or if it has any value.
Re: Model T magneto Regulator ?
Post by RajoRacer » Wed Mar 12, 2025 10:17 pm
Magneto powered battery charger, I believe.
Modeltmike
Last Name: Sleep
Post by Modeltmike » Wed Mar 12, 2025 11:16 pm
For an early non-starter cars that use a “helper” battery to ignite coils. This would charge that battery?
RecklessKelly
Last Name: Maxson
Post by RecklessKelly » Thu Mar 13, 2025 8:52 am
The website is dead, is True-fire out of business?
Ron Patterson
Post by Ron Patterson » Thu Mar 13, 2025 10:36 am
Mike
Beware.
It will charge a battery but when it is fully charged the internal
circuitry will render the magneto useless for driving because it cuts off 1/2 of the
magneto waveform connected to the coils.
Ron Patterson
RVA23T
Last Name: C
Post by RVA23T » Thu Mar 13, 2025 2:35 pm
Mike
Beware.
Ron Patterson
Even when wired parallel off the magneto?
Post by TXGOAT2 » Thu Mar 13, 2025 5:32 pm
Bridge rectifier?
Kerry
Last Name: van Ekeren
Post by Kerry » Thu Mar 13, 2025 5:44 pm
It is a shame that they are not made any more, I use a 6v bittner charger and a E timer so I have good lights on a 16 for many years, a much better set up than the diode and globe on the mag.
