Ok
New to model t
I had the coils rebuilt
I had the carb rebuilt
Cleaned the plugs
And it won’t start
Tried the cleaning of the timer
It is a new day timer
Could it be the key switch?
Also I’m trying to find a club near me
I’m between Philadelphia and Allentown in the eastern part of Pa
Any help I will try
It has to something easy
VFeditor_Aleesa
- First Name: Aleesa
- Last Name: Drennen
Re: It has to something easy
Sent you an email with information on two Club Chapters in your general vicinity.
Aleesa – Vintage Ford Editor
What's Your Story?
What's Your Story?
- Last Name: Humble
Do the coils buzz on battery?
KeithG
- First Name: Keith
- Last Name: Gumbinger
They will if the timer is in the right position and the battery and wiring is ok. You could move the timer rod up and down and you might get them to buzz.
Keith
Keith
You need to hear each individual coil buzz as you slowly turn the engine over with the spark lever retarted for the engine to start. No buzz is a no go. Could be the switch is dirty if you don’t get a buzz. Turn the key quickly back and forth and see if you get a buzz. If you do the switch contacts are dirty or need adjusting.
Jwinters
Topic author - Posts: 25
- First Name: Joseph
- Last Name: Winters
- * REQUIRED* Type and Year of Model Ts owned: 1923 pickup
The coils wouldn’t buzz at all
I am going back out to try the adjustments for the timer.
The timer isn’t new but it didn’t look like it had anything wrong with it
It hasn’t run in 27 years but that’s all going to change this week
Thanks for the club information
I will reach out to them this week
Duey_C
- First Name: Duane
- Last Name: Cooley
The 18 that lives here has kind of the same issue. Over the winter, the electrical's for the coils have gone languid.
Let us know. when you find out what.
