Ford Dealer Gasket Board
Last Name: Hatch
Post by Dan Hatch » Sat Mar 15, 2025 3:03 pm
Friend just gave me an original Ford gasket board with bad graphics. Just so happens I have one of Tim’s reproduction gasket board graphics.
Question is what is the backing behind the paper graphics? Look like some kind of poster board. Any one replaced this ? If so what did you use? This one is deformed a little, was wondering about maybe pressing it with a warm iron to flatten it before applying the graphics. Any ideas ? Thanks Dan
Re: Ford Dealer Gasket Board
Post by RajoRacer » Sat Mar 15, 2025 3:18 pm
I can't remember - mine's been up there for so long - it was pretty stout paper board, though !
Tim used mine for his copy.
Last Name: Hatch
Post by Dan Hatch » Sat Mar 15, 2025 3:57 pm
Got the frame and most of the hooks. The backing is kind of warped. Thinking about using thin plywood to replace it. Then glue his graphic to it.
Looks like a heavy paper type of poster board. Thanks Dan
Last Name: Hatch
Post by Dan Hatch » Sun Mar 16, 2025 8:19 pm
No input on replacement for the backing?
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Sun Mar 16, 2025 11:40 pm
Perhaps 1/8" or 3/16" dense particle board? Not the light colored pressed wood, but the very dense and hard dark brown particle board, that you have to drill to make a hole in. I'm not sure what the technical name of it is. It has a shiny finish that is very hard. It is almost like brown phenolic, but made of compressed resin and paper.
RVA23T
Last Name: C
Post by RVA23T » Mon Mar 17, 2025 5:53 am
Tempered Hardboard is what you are referring to. Peg boards are also made of it.
Last Name: Seth
Post by perry kete » Mon Mar 17, 2025 8:03 am
Try to locate picture matting board material it is thick and comes in a variety of colors. Perhaps someone who frames photographs and posters could assist you in locating it.
katjack78
Last Name: Jackson
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1927 Speedster
Post by katjack78 » Mon Mar 17, 2025 5:00 pm
I believe the hard board you are referring to is "MASONITE". Hope this helps.
Post by Original Smith » Tue Mar 18, 2025 12:45 pm
I've got one. They were not the best quality!
