Reclining Seats?
GarJen127
Topic author - Posts: 111
- First Name: Garrett
- Last Name: J
- * REQUIRED* Type and Year of Model Ts owned: None
Reclining Seats?
Do all touring have adjustable seat? I’ve seen some camping photos of touring being used as beds.
WayneJ
- Last Name: Jorgensen
Re: Reclining Seats?
It was an aftermarket conversion kit that allows the front seats to recline. Not factory equipment.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
Front seat back cut down the sides & bottom, I believe some additional framing added and tacked in, hinges added to the bottom, brackets up top, the upholstery cut down the sides and retacked either side...
To recline, the outer screw on each bracket removed to unlock the seat back and recline the back, where the seat bracket is then rescrewed into a receiver that's added to both the rear seat door frames along the riser to lock it in place level.
The bed...if you want to call it that, is only 5 feet long from the rear seat back to front riser. Sleep upright, or spoon with your partner.
Daisy Mae had this modification done for its cross country trip MI to Colorado Springs for the race in '16
- Last Name: House
Those photos are very interesting to me. I’ve heard of that accessory for quite some time but have never viewed it. Thank you for sharing the photos Kurt…
Colin Mavins
- First Name: Colin
- Last Name: Mavins
This 1911 was for sale on ebay years ago
