Low Head
Mountainrider
Topic author - Posts: 178
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Low Head
I have a 18 engine in my 15 t right now with a high head. My 15 low head head is in good condition. Will I notice much in hill pulling power installing it. I’m not looking for speed just more hill power. I was originally planning on installing a z head.
Head and manifold might be for sale.
Mountainrider
- First Name: Neil
Re: Low Head
It seem most T owner are also T parts hoarders. I also have some a extra set of light weight connecting rods with almost new Babbitts. Do I hoard them or sell them.
Kerry
- Last Name: van Ekeren
Re: Low Head
Neil,
That's an awful big hole for the #3 spark plug, as for saving the rods, only good if you have the matching size crank, if still STD not easy to find a good one these days.
Mountainrider
- First Name: Neil
Re: Low Head
Haven’t put the new helicoil in it yet.
Re: Low Head
I would skip the low Ford head for the Z head. At least the difference in performance will be noticable. If you haven't bought the Z head already, I would skip again to a Prus head.
Mark Osterman
- Last Name: Osterman
Re: Low Head
I recently installed a U&J carburetor on an otherwise stock 1923 engine. The hill climbing energy has been really great. Can’t imagine it with a high compression head.
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Low Head
I’m curious about what sort of thread repair you are using? That hole looks way too big for a Helicoil.
- Last Name: Humble
Re: Low Head
Neil, if I understand your question, you want to know if you will notice a difference in power between a stock high head and a stock low head. The primary difference between a low head and a high head is not combustion chamber, it is coolant volume.
Powerwagonmaniac1
- First Name: Chris
- Last Name: Becker
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1917 speedster, 1925 give or take roadster pickup
Re: Low Head
If you decide to sell the rods how much would you want for the set what size are they?
Ruxstel24
- Last Name: Hanlon
Re: Low Head
What Allan said...
