Is this a Model T? If not, what is it?
KellyJons
Topic author - Posts: 59
- First Name: Kelly
- Last Name: Jons
This car belonged to the grandfather of a friend of mine and he would like to know if it is a Model T. I don’t know enough to answer that question but I figured you guys would.
He would also like to know what all of the levers are on the side of the car above the running board.
Thanks for your help!
Kelly
Kelly
Re: Is this a Model T?
Doug's first car was not a Model T. The levers were a gear shift and a parking brake. The lever he has his hand on is the gear shift.
KellyJons
- First Name: Kelly
- Last Name: Jons
Re: Is this a Model T? If not, what is it?
And the straight rod in front of that is a windshield brace, and the curly rod or pipe in front of that is from a gas generator to the carriage lamp?
It’s hard to tell from the photo but it sure looks like the gearbox is sitting on the running board.
Kelly
Kelly
The "curly rod" is the tubing for the bulb horn. The bulb itself being just below Doug's wrist. What you might think of as the gearbox is the carbide generator, which makes acetylene gas for the headlamps. The actual gearbox would not be seen.
It's an odd make of car for sure.
KellyJons
- First Name: Kelly
- Last Name: Jons
Adjusted exposure and definition and cropped the result:
I would suggest copying that last image and ask on the "What is it" section over on the AACA site. To me it does not look American.
https://forums.aaca.org/forum/66-what-is-it/
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
- Board Member Since: 2024
It almost looks like an '09/'10 American Underslung, but with a homemade body tail.
ModelTMitch
- First Name: Mitch
- Last Name: Taylor
- * REQUIRED* Type and Year of Model Ts owned: 1924 Ford Model T touring
- Location: https://www.fordmodelt.net (Manning Valley, NSW, Australia)
It's not a Model T, but it looks a bit like the 1909 Humber 8HP which was used in Chitty Chitty Bang Bang, although the Humber used in the movie did not have a windscreen.
☆☆ ModelTMitch ☆☆
★ Website: https://www.fordmodelt.net
★ YouTube: https://www.youtube.com/@ModelTMitch
★ Twitter: https://www.twitter.com/modeltmitch
★ Car Club: https://www.glhac.org
