Is this a Model T? If not, what is it?
KellyJons
First Name: Kelly
Last Name: Jons
Post by KellyJons » Wed Mar 19, 2025 4:28 pm
This car belonged to the grandfather of a friend of mine and he would like to know if it is a Model T. I don’t know enough to answer that question but I figured you guys would.
He would also like to know what all of the levers are on the side of the car above the running board.
Thanks for your help!
Kelly
Re: Is this a Model T?
Post by Jerry VanOoteghem » Wed Mar 19, 2025 5:45 pm
Doug's first car was not a Model T. The levers were a gear shift and a parking brake. The lever he has his hand on is the gear shift.
KellyJons
First Name: Kelly
Last Name: Jons
Re: Is this a Model T? If not, what is it?
Post by KellyJons » Wed Mar 19, 2025 6:17 pm
And the straight rod in front of that is a windshield brace, and the curly rod or pipe in front of that is from a gas generator to the carriage lamp?
It’s hard to tell from the photo but it sure looks like the gearbox is sitting on the running board.
Kelly
Post by Jerry VanOoteghem » Wed Mar 19, 2025 7:05 pm
Kelly
The "curly rod" is the tubing for the bulb horn. The bulb itself being just below Doug's wrist. What you might think of as the gearbox is the carbide generator, which makes acetylene gas for the headlamps. The actual gearbox would not be seen.
It's an odd make of car for sure.
KellyJons
First Name: Kelly
Last Name: Jons
Post by KellyJons » Wed Mar 19, 2025 9:47 pm
Adjusted exposure and definition and cropped the result:
Last Name: Gregush
Post by Mark Gregush » Thu Mar 20, 2025 3:15 pm
I would suggest copying that last image and ask on the "What is it" section over on the AACA site. To me it does not look American.
https://forums.aaca.org/forum/66-what-is-it/
Daisy Mae
First Name: Kurt
Last Name: Andersson
Board Member Since: 2024
Post by Daisy Mae » Fri Mar 21, 2025 3:31 pm
It almost looks like an '09/'10 American Underslung, but with a homemade body tail.
ModelTMitch
First Name: Mitch
Last Name: Taylor
* REQUIRED* Type and Year of Model Ts owned: 1924 Ford Model T touring
Location: https://www.fordmodelt.net (Manning Valley, NSW, Australia)
Post by ModelTMitch » Sat Mar 22, 2025 4:04 am
It's not a Model T, but it looks a bit like the 1909 Humber 8HP which was used in Chitty Chitty Bang Bang, although the Humber used in the movie did not have a windscreen.
1909 Humber 8HP
1909 Humber 8HP
☆☆ ModelTMitch ☆☆
★ Website: https://www.fordmodelt.net
★ YouTube: https://www.youtube.com/@ModelTMitch
★ Twitter: https://www.twitter.com/modeltmitch
★ Car Club: https://www.glhac.org
