Bendix Cover Screws: Size?
Post by Jerry VanOoteghem » Mon May 29, 2023 5:24 pm
A discussion came up at a Model T Tech Talk at the Piquette Plant. One guy stated the screws were 1/4-24, while another suggested they are 10-27. I'm leaning towards 10-27. We all know they're "special" of course. Anybody know for sure the size?
Re: Bendix Cover Screws: Size?
Post by Scott_Conger » Mon May 29, 2023 5:30 pm
Neither, Jerry
they're 14-24 ASME Standard (with uncommonly small diameter heads)
George Mills
Last Name: Mills
Post by George Mills » Mon May 29, 2023 5:38 pm
14-24
(Or as the late Ralph Ricks use to say….use an M6 x1…just enough drag to keep ‘em from backing out…and built in advantage of a hex key to get that 3 o’clock one! )
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Mon May 29, 2023 5:43 pm
14-24
When i monkey with my bendix cover, I leave the three o’clock one in place
William L Vanderburg
1922 Center Door Sedan
Post by Steve Jelf » Mon May 29, 2023 5:56 pm
Nobody asked, but I'll show how I get them started with a long screwdriver. :)
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Mon May 29, 2023 6:22 pm
I use a screw driver that holds the screw. It has jaws on each side of the screw head.
Without that I would probably use a 6x1mm 10 mm long
Art Mirtes
Post by Jerry VanOoteghem » Mon May 29, 2023 6:33 pm
Thanks all!!!
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Post by Rod » Fri Mar 21, 2025 5:46 pm
I sure wish that I had read this post before driving all over town looking for 1/4”-24 bolts. I finally did the math in my head and realized that a 6mm bolt is the same diameter. After counting the threads at the hardware store it was exactly 24 threads per inch. I bought hex head bolts but had to grind the flange as the diameter was too large. I should have bought the allen head type. What an ordeal to install the bendix cover.
Post by speedytinc » Fri Mar 21, 2025 5:51 pm
Vendors sell the correct screws.
Ron Patterson
Post by Ron Patterson » Fri Mar 21, 2025 6:03 pm
As correctly stated aboove.
Save-Bendix Cover Screw Print.jpg (28.79 KiB) Viewed 2387 times
14-24 ASME Standard
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Post by South Park Zephyr » Fri Mar 21, 2025 10:22 pm
For ease of removal, I chose to use hex head cap screws I gave up on originality for ease of installation. A long Allen socket sure makes installation and tightening easier. I wouldn’t do it on a restoration, but for a driver, it made life much easier. I found a source for them thru a motorcycle supply shop.
Scott
Post by Steve Jelf » Sat Mar 22, 2025 12:00 am
The guys who said 14-24 (not ¼) almost two years ago seem to still be right. I guess a length of ¾" is OK, but to me that seems kind of long.
Post by DanTreace » Sat Mar 22, 2025 9:31 am
Be sure to add lock washers under the Bendix screw heads. Find small metic lock washers at the hardware, they have to be small diameter. A loose cover and oil leaks, and can be catastrophic :o
A long thin single blade screw driver and a locking tip one really aids in install of the cover.
IMG_3718 (700x525) (600x450).jpg (141.24 KiB) Viewed 2262 times
Post by RajoRacer » Sat Mar 22, 2025 11:08 am
The above Ford drawing illustrates the length at 15/32"- just under a 1/2".
Last Name: Hatch
Post by Dan Hatch » Sat Mar 22, 2025 11:40 am
Back in the day we would tap them 1/4 x 20 and use socket head cap screws. Easy to install with a long Allen wrench. Also easy to find on the road if you lose one.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Sat Mar 22, 2025 12:17 pm
Back in the day we would tap them 1/4 x 20.......
That's what I did 50 years ago. No one can tell. No one cares.
Last Name: Hatch
Post by Dan Hatch » Sat Mar 22, 2025 12:20 pm
And we sealed the cover with a little MBRT. Worked wonders!
Post by John kuehn » Sat Mar 22, 2025 6:27 pm
The picture of the screwdriver Dan T posted works wonders to hold screws in a the screwdriver so you can get them started! We used that type where I use to work to hold screws to get them started in switch panels, pressure switches and screws in tight places. Every mechanic needs one or two of these locking tip screwdrivers. No kidding and once you use one you’ll wonder where have I been!
And seems like I remember you can leave one of the covers screws in to help hold the cover in place and then install the rest.
Last Name: Hatch
Post by Dan Hatch » Sat Mar 22, 2025 7:18 pm
John we called those “ Monday morning screwdrivers”.
