When did they stop using the wooden blocks between the fenders and running boards?
Thanks,
Stephen
Running Board Block
Topic author - Posts: 386
- First Name: Stephen
- Last Name: Heatherly
Re: Running Board Block
They were used on the 1927 Model T.Stephen_heatherly wrote: ↑Sun Mar 23, 2025 10:32 pmWhen did they stop using the wooden blocks between the fenders and running boards?
Thanks,
Stephen
- First Name: Thomas
- Last Name: Miller
1921?
The vendors parts catalogs offer 8 piece block sets with usage through 1920.
Tom Miller
- First Name: Vernon
- Last Name: Worley
Our October 26, 1926 ('27) T has blocks between the running boards and the support brackets but not between the running boards and the fenders. If it is supposed to have them there, i don't know anything about it.
Vern (Vieux Carre)
- Last Name: Strange
Here is an old thread on the blocks and washers. https://www.mtfca.com/discus/messages/3 ... 1364944552
- Last Name: Bartsch
RB Blocks- https//www.modeltford.com/item/4822B.aspx price slightly higher than original 4/twenty cents.
For '26-'27, front fender flange mounts to running board flange, no blocks
- Last Name: Codman
