KW Wood Coilbox
Topic author - Posts: 3914
KW Wood Coilbox
The KW wood coilbox used only in 1913 uses non insulated silver colored stranded wire about 14 AWG. I'm wondering if this type of wire is still available?
Re: KW Wood Coilbox
Larry,Original Smith wrote: ↑Fri Mar 14, 2025 1:09 pmThe KW wood coilbox used only in 1913 uses non insulated silver colored stranded wire about 14 AWG. I'm wondering if this type of wire is still available?
It's "buss wire". Tin coated copper wire.
https://www.mcmaster.com/products/bus-wire/
https://sea-wire.com/aa59551/
OOPS... missed the part about it being stranded wire.
Last edited by Jerry VanOoteghem on Fri Mar 14, 2025 2:46 pm, edited 2 times in total.
Re: KW Wood Coilbox
Couldn't find it bare. 14 AWG bare stranded hookup wire
You may need to strip the wire 14 AWG marine grade hookup wire
This listed the best match & at Home Depot too
https://www.homedepot.com/p/Ancor-Marin ... /316303205
Looks like purple is on-sale other colors are higher
Re: KW Wood Coilbox
Interesting. That is what I did, however, I was unaware of marine grade stranded wire. Thanks for the information !
Re: KW Wood Coilbox
I had to go to a marine supply store to find it. It is not twisted but is the correct wire I was looking for. All that needs to be done is the insulation stripped off, and then twisted. #14 AWG.
Re: KW Wood Coilbox
You might ned to check the number of strands before twisting it.
