Head Light Identification
Harley_97
First Name: Roger
Last Name: Hallett
* REQUIRED* Type and Year of Model Ts owned: 1924 Runabout, 1917 Runabout
Post by Harley_97 » Mon Apr 07, 2025 10:03 am
I have this one head light that looks similar to a model T, but I don't think it is, I am hoping someone ID it.
It is 10-inchs in diameter, original glass with bubbles.
First Name: Keith
Last Name: Townsend
Re: Head Light Identification
Post by KWTownsend » Mon Apr 07, 2025 11:14 am
Is there any inscription around the socket?
It looks similar to the E&J 440 that was used on early Canadian 1915 cars.
Post by TXGOAT2 » Mon Apr 07, 2025 12:12 pm
Glass with bubbles may be window glass cut to replace a lens.
Harley_97
First Name: Roger
Last Name: Hallett
Post by Harley_97 » Mon Apr 07, 2025 4:47 pm
Keith, no inscription or markings anywhere that I can see on the out the side, I will have to try and open it maybe the reflector has some markings on it.
Pat, here is a close up of what I see as bubbles or air pockets.
Post by Allan » Mon Apr 07, 2025 6:01 pm
At 10" round it is larger than the fork mounted light used on Canadian 1915 cars. They are the same size as later standard Ford electric lights.
Post by TXGOAT2 » Mon Apr 07, 2025 7:50 pm
Olds style structural type window glass often had bubbles and ripples in it. I've never seen such blemishes in a headlight lens.
Harley_97
First Name: Roger
Last Name: Hallett
Post by Harley_97 » Tue Apr 08, 2025 9:02 am
Being that the fork mount doesn't have set screws or bolts as the Model T lights did, the vehicle that this light came from must have had threaded forks. Both top and bottom have been machined.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed Apr 09, 2025 7:26 pm
Chev 490 from the late teens used headlights similar to this.
