Wheeler muffler
First Name: Keith
Last Name: Townsend
Wheeler muffler
Post by KWTownsend » Tue Apr 08, 2025 4:04 pm
Does anyone have any information about one of these?
First Name: Adrian
Last Name: Whiteman
Re: Wheeler muffler
Post by A Whiteman » Tue Apr 08, 2025 4:21 pm
I particularly like the description: "Motor Testing Valve"
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Re: Wheeler muffler
Post by TMiller6 » Tue Apr 08, 2025 4:31 pm
134 East Jefferson is now the entrance of the Detroit-Windsor Tunnel.
Tom Miller
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Re: Wheeler muffler
Post by KBurket » Tue Apr 08, 2025 4:52 pm
Older post discussing wheeler and other home made versions.
http://www.mtfca.com/discus/messages/82 ... 1530408436
First Name: Keith
Last Name: Townsend
Re: Wheeler muffler
Post by KWTownsend » Tue Apr 08, 2025 5:35 pm
Open:
Closed:
Outlet:
The outlet looks a little small.
Re: Wheeler muffler
Post by RajoRacer » Tue Apr 08, 2025 7:43 pm
Appears to be similar in size to a standard T muffler outlet.
First Name: Keith
Last Name: Townsend
Re: Wheeler muffler
Post by KWTownsend » Tue Apr 08, 2025 11:02 pm
I believe this was fabricated with Model T muffler ends. I'm thinking that outlet port s a little small...
First Name: Keith
Last Name: Townsend
Re: Wheeler muffler
Post by KWTownsend » Wed Apr 09, 2025 6:16 pm
I'm curious about the construction.
The pipe from the manifold is about 1-1/2" in diameter.
It is welded onto a pipe that is about 3" in diameter.
Does the 1-1/2" pipe go farther into the 3" pipe?
The muffler part looks to be made from late stamped muffler ends.
I suppose the center shell is not used, but the middle one is used?
The 3" pipe on the end has a butterfly valve to open for straight pipe, or divert exhaust through the other shell.
I would like to see a cutaway diagram.
Thanks,
Keith
