Roadster front top bow length
Topic author - Posts: 8
- First Name: Tex
- Last Name: Holtby
- * REQUIRED* Type and Year of Model Ts owned: 25 runabout , 25 runabout pickup
Can anyone provide the length of the exposed wood on the front bow of a 25 roadster? I just need the exposed wood length from socket to socket (not including the toungs). Thanks!
- First Name: Tex
- Last Name: Holtby
Re: Roadster front top bow length
Found an original front bow so I'm all set!
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
If I remember back to my roadster top, all the top irons were the same width and lined up when the top was in the folded position. Mixing and matching bows from other tops may or may not produce the results you expect. Match the front iron to your other top irons, that will determine your bow width.
- Last Name: Osterman
I have an original wood bow for the front if you want me to measure it.
On a 25 the length must be correct so that the clamps which hold the top to the windshield posts will fit correctly. Not too short nor too long. It could vary from one set of irons to another, so be sure it fits.
- First Name: Gary
- Last Name: Simpson
- * REQUIRED* Type and Year of Model Ts owned: 1924 MODEL T ROADSTER
looking for a used set of bows for a 1924 Roadster live 20 miles north of Lansing mich. not a rich man
- First Name: Tex
- Last Name: Holtby
Norm, that's exactly how I ended up assembling it! Perfect fit! Tex
