Mystery Crankshaft
Mark Chaffin
Last Name: Chaffin
Mystery Crankshaft
Post by Mark Chaffin » Mon Feb 03, 2020 11:10 am
I located this beautiful counterbalanced billet crankshaft and would like to see if anyone may know who may have manufactured it. I was unable to locate a name on the crankshaft other than a faint number 1103. The main journals measure 1.625. The rod journals measure 1.480. Stroke is 4". The journals are protected by a protective coating. It appear to be in new condition. Thanks for your assistance.
Mark Chaffin
Last Name: Chaffin
Re: Mystery Crankshaft
Post by Mark Chaffin » Mon Feb 03, 2020 11:11 am
Also forgot to mention. It has been cross drilled for oil pressure.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Feb 03, 2020 12:36 pm
All I can offer is that I would certainly use it!!
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Mon Feb 03, 2020 2:09 pm
WE NEED A "LIKE" BUTTON!!
Post by Wayne Sheldon » Mon Feb 03, 2020 4:03 pm
Beautiful! And very interesting.
-Warning- Looks like I may be the "downer" for the day.
But,I don't think I like the method of cross-drilling for pressurized oiling. Given the position of the holes I can see, it is multiple intersecting paths, which remove more internal material with greater exposure to outer surfaces. Such a "lattice" of drilling creates more potential fracture points than simple single angled drilling (IF such single drilling is practicable, which looks to me like it could have been done?).
Worse. I don't like the looks of a couple of the radius cuts on the end of the journals. The worst one looks to be the rear of the center main (almost square). A couple others don't look bad? but the transition from plane to plane is not smooth enough.
If it were mine? I don't think I could resist using it. And it would probably run a long time. But I wouldn't be surprised when it broke either.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Feb 03, 2020 6:11 pm
Mark- I believe I have an identical crank minus the cross drilling on the rod journals.
Dan
Mike Penserini
Last Name: Penserini
* REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Post by Mike Penserini » Mon Feb 03, 2020 9:49 pm
I have a similar crankshaft with no counterweights and a 3 inch stroke.
T4Tom
Last Name: Magee
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster
Post by T4Tom » Mon Feb 03, 2020 10:19 pm
Are any of those Fronty cranks?
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Mon Feb 03, 2020 10:44 pm
No. one picture, looks like it has been ground up to the Radius, and left a right angle. Closer pictures would take the guess work out of it.
I was looking at No. 1 Pin, the closest Radius, to the front of the crank.
Here was one of the Model T cranks that, Vern, at Arnold Motor, in Fort Dodge, Iowa Ground. His cranks were perfect in every way.
Herm.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Feb 03, 2020 10:48 pm
I want to say it is almost identical to the bottom picture Tom posted above. It looks very similar.
Kevin_m
First Name: Kevin
Last Name: McGinnis
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1926 Speedster, 1910 Speedster
Post by Kevin_m » Tue Feb 04, 2020 8:31 pm
I am fuzzy on the details, but that kinda looks like a "Joe Morris" (?) crankshaft. I have one in my speedster, but it has been over 25 years since I've seen it (fortunately). I hear they have problems. Hope others will chime in with better info. I think Joe resided somewhere in the California Sierra foothills.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Feb 04, 2020 10:29 pm
The Joe Morris cranks were very similar in appearance to this crank... but were fabricated from multiple pieces and welded together. Joe made no attempt to hide his assembly process and his cranks are instantly recognizable
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Wed Feb 05, 2020 10:24 am
Lots of very good information provided. Thank you very much.
Ujustwaite
First Name: Brian
Last Name: Waite
* REQUIRED* Type and Year of Model Ts owned: B.H. Lawwell Special (1917-1921 Fairgrounds Racer)
Post by Ujustwaite » Sat Apr 19, 2025 12:02 pm
Hi Friends,
I know it has been some time since this thread was alive, but I recently came into possession of what I believe is a Joe Morris crankshaft inside of an engine block that is bored .080 over with aluminum pistons. It matches the description of the welded / press fit construction. Images of the block and crank were posted on Facebook from the guy I bought it from and people there identified it as a Joe Morris crank. I have a Roof 'C' racing head that will ultimately pair with this after I complete my current Roof BB project.
Best,
Brian
Post by TXGOAT2 » Sat Apr 19, 2025 12:12 pm
Why put grooves in the mains? I'd put them in the babbitt, not the crank. Much better than stock, regardless.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sat Apr 19, 2025 12:55 pm
That is certainly a Joe Morris crank or one made to his design. Joes 1st made cranks for 2 cylinder Reo engines and then expanded the idea to a model T crank. After Joe stopped making them, a few were made by the fellow that worked with Joe. More than a few were made with almost no fillet in the rear main that resulted in snapped off flanges. Their solution at the time appeared to make the flanges thicker, which did nothing to solve the initial problem. Some were drilled for oil to the rod journals. If you decide to run it, just be aware of the reality of a multiple piece crankshaft.
Ujustwaite
First Name: Brian
Last Name: Waite
Post by Ujustwaite » Sun Apr 20, 2025 2:34 pm
Thanks Dan! Is there a good place to look for history / documentation of Joe's work? Did he have a machine shop as a profession or was he a hobbyist? I'd be really interested in reading up on him. Yes, understand the concerns about potential failure. May just get a scat and keep this for history...or not. ;)
