Timing Cover Alignment Tool
BRENT in 10-uh-C
Topic author - Posts: 488
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Does/Are any vendors selling Bob's style of alignment tool? If so, who is selling them??
TIA
TIA
Line_Noise
- First Name: Derek
- Last Name: Dudgeon
- Board Member Since: 2022
Re: Timing Cover Alignment Tool
Ebay seller "burnzoil" makes and sells them. He has also sold in the classifieds here, but it has been a while and I forget his username.
No idea, but I think any decent machine shop could make a simple alignment tool. Picture a round piece of metal exactly the diameter of a timer cover, with a hole exactly in the center that slips onto the end of the cam shaft.
Moxie26
- Last Name: Jablonski
Lang's ran out of stock tools ????
- Last Name: Hatch
K R Wilson sold them
Ed Fuller
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
The late Bob Scherzer reproduced the KR Wilson tool.
Rich Bingham
- First Name: Rich
- Last Name: Bingham
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
Link to eBay Seller.
https://www.ebay.com/itm/266276801263?i ... R6b3z83KZQ
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
Thanks Steve. I have two of the aluminum ones that index on the cam seal flange but I am finding those are hit/miss on whether they index correctly. I had a large one from years ago that Bob had made but it appears it is now MIA. I may just machine a piece of aluminum that will index off of that little one and the larger ring will slide over the small one.Steve Jelf wrote: ↑Sun Apr 20, 2025 10:24 amNo idea, but I think any decent machine shop could make a simple alignment tool. Picture a round piece of metal exactly the diameter of a timer cover, with a hole exactly in the center that slips onto the end of the cam shaft.
Thanks everyone.
Those are the ones Langs sells that used the seal area. My preference would be the KRW style. I too was going to suggest Gene French. Pretty sure he makes the style that indexes off the machined recess the timer fits into.BRENT in 10-uh-C wrote: ↑Sun Apr 20, 2025 7:35 pmThanks Steve. I have two of the aluminum ones that index on the cam seal flange but I am finding those are hit/miss on whether they index correctly. I had a large one from years ago that Bob had made but it appears it is now MIA. I may just machine a piece of aluminum that will index off of that little one and the larger ring will slide over the small one.Steve Jelf wrote: ↑Sun Apr 20, 2025 10:24 amNo idea, but I think any decent machine shop could make a simple alignment tool. Picture a round piece of metal exactly the diameter of a timer cover, with a hole exactly in the center that slips onto the end of the cam shaft.
Thanks everyone.
KurtM
- First Name: Kurt
- Last Name: Maurer
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout
How necessary are these tools? What happens if you replace a timing gear without one?
You have a very good chance of either "roller bounce" or in the case of distributor gear mesh, a "not good" scenario ! The only one that actually centers the timing cover IS the large diameter tool !
KurtM
- First Name: Kurt
- Last Name: Maurer
Thanks Steve, anyone else? I ask because I just changed the timing gear on my '23 Runabout without the centering tool 'cuz I didn't have one. The car's mostly original, sporting a New Day timer. My buddy put his together without the tool a while back and his car runs great, is why I went ahead instead of ordering a tool and waiting a week to get my car back on the road. He had a roller, and then switched to a flapper type of timer, if I have the terms anywhere near correct or at least understandable.
Rich Bingham
- First Name: Rich
Kurt, I may be wrong about this, but I think the configuration of the New Day is such that it “forgives” the timing cover being less than perfectly centered over the camshaft.
At least that was my experience 63 years ago, when, as a dumb kid I found I couldn’t keep the factory roller timer operating properly - switching to a New Day, problem solved ! At the time, I didn’t know the timing cover had to be centered over the camshaft with a special tool.
"Get a horse !"
I agree that the design of the New Day should make it immune to the slight cover misalignment that sometimes means trouble for a roller timer. I've used New Day for many years, and my lack of a centering tool has not been a problem. Should we all have one? Sure. Better safe than sorry.
jab35
- Last Name: Bartsch
I made one from an original Ford timer by turning a block of maple to a moderate press fit in the case with original contact ring removed, and bored a hole to fit camshaft. Used it once with good result, fwiw. jb
