closed cab stamped steel door key question
WillyR
First Name: Vilhelm
Last Name: VonRaschke
* REQUIRED* Type and Year of Model Ts owned: 1924 coupe
Post by WillyR » Wed Apr 23, 2025 9:19 am
I have just a single stamped steel door key for my 24 coupe.
Are these keys numbered and available like ignition keys?
Are there blanks available?
how would I go about getting a couple more copies?
CF736 is the number on my key..
As an aside, I would also like another trunk key, are all of these the same?
I will pick up a third ignition key off the ebays to have 3 complete sets.
A vendor or two has a new tumbler with two more modern keys that could possibly be easier to replicate for under $20 would it be worth it to switch the tumbler?
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
WillyR
First Name: Vilhelm
Re: closed cab stamped steel door key question
Post by WillyR » Wed Apr 23, 2025 10:24 am
I did find out from a trusted vendor, the available tumbler/2 key set will only work with "half turn" locks.
mine does lock with half a turn, so I may be good there....
I guess the other type is "quarter turn"
they also have an extra ignition key for much less than the ebays, but the extra trunk key price makes up for that.......
WillyR
First Name: Vilhelm
Post by WillyR » Wed Apr 23, 2025 5:07 pm
I was waiting on an back ordered item from Lang's and it came in today, so I added the tumbler and keys along with some other items.
I will see if any local locksmiths can provide copies of my original, and if have a leftover tumbler and keys, I may just have to buy a tudor to go with it..
