Warford
ryanpad
First Name: Vincent
Last Name: Ryan
* REQUIRED* Type and Year of Model Ts owned: 1913 TOURING CONVERSION
Board Member Since: 2023
Warford
Post by ryanpad » Thu Dec 12, 2024 9:01 pm
I’m on the list for a Layne Warford Transmission but haven’t heard back on it. Has anyone out there received theirs yet?
ryanpad
First Name: Vincent
Last Name: Ryan
Re: Warford
Post by ryanpad » Fri Apr 25, 2025 3:36 pm
My gearbox is done, should be here in a week or so. Now to study up on axle/differential removal and repair as to coincide with the installation of the Warford.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: Warford
Post by mtntee20 » Fri Apr 25, 2025 4:19 pm
You're going to LOVE that new Warford. I DO.
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Re: Warford
Post by South Park Zephyr » Fri Apr 25, 2025 4:43 pm
I’ve had mine for going on 4 years now. It makes the car enjoyable to drive, for sure. Don’t be afraid to force it into gear, it sometimes seems difficult but it gets easier with practice. I banged it pretty hard learning to drive it. I was worried I had done some damage once so I pulled the cover off, I was fine. They can take some abuse (within reason). The only thing I need to do to mine is bend the shift arm a bit. I sometimes will knock it out of gear with the back of my knee.
Do you have auxiliary brakes? If not, get some.
I have Rockies on mine and am very happy with the setup.
ryanpad
First Name: Vincent
Last Name: Ryan
Re: Warford
Post by ryanpad » Fri Apr 25, 2025 6:19 pm
I do have brakes. I have to refurbish them still. The casting has Miller Brake embossed on it. I’d like o keep them but not opposed to buying Rocky Mountain if I can’t get these working.
Re: Warford
Post by Allan » Fri Apr 25, 2025 8:14 pm
I made an extension for the shift lever, and it is angled back to put the knob next to my knee. With my hand on my knee I can make imperceptible changes just by moving my knee. Neat trick. By far the best thing you can do is fit a foot accelerator pedal. This makes it much easier to get the motor into an appropriate rev range for the gear to be selected. The box will take heavy shifts, but with matched engine speed it wiil change just like a clutchless change in Roadranger in a semi.
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Re: Warford
Post by Will » Sat Apr 26, 2025 12:28 pm
What is the difference between this transmission compared to the ones Langs sells? I'm looking forward to getting one at some point for my 19 and removing the Ruckstell rear
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Re: Warford
Post by RajoRacer » Sat Apr 26, 2025 2:10 pm
Only one company produces the new "Warford".
ryanpad
First Name: Vincent
Last Name: Ryan
Re: Warford
Post by ryanpad » Mon Apr 28, 2025 5:43 pm
I don’t know that Langs sells them but if you contact Layne Machine you should be able to get one. I was on a waiting list and just recently got the call from John. I’ve heard lots of good stuff on this modern version with synchronized gears. They also shorten your drive shaft and torque tube included in the price.
footpowered
First Name: Kim
Last Name: Doty
* REQUIRED* Type and Year of Model Ts owned: 1921 runabout pickup. 1923 depot hack
Re: Warford
Post by footpowered » Thu May 01, 2025 8:27 am
I just received my Warford this week. I got on the list at the end of October so it was right at 6 months.
John allowed me to send them my driveshaft and torque tube for shortening while I waited so now I have everything ready to go for the installation.
That worked out great.
ryanpad
First Name: Vincent
Last Name: Ryan
Re: Warford
Post by ryanpad » Fri May 02, 2025 6:07 pm
Got mine today!
