Aluminum Head Electrolysis
Topic author - Posts: 504
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
Has anyone had any experience using a product "Lucas Oil Super Coolant" in their Ts with aluminum heads to control electrolysis?
- Last Name: Pharis
Re: Aluminum Head Electrolysis
Looks to be equivalent to Red Line’s Water Wetter, which I have used for a while and am happy. Note the part where it says “does not protect from freezing”, not a problem for me here in Califunny, but might be in other parts of the world
https://www.lucasoil.com/pdf/03_ProblmS ... nt_PDS.pdf
From DeWitts Radiator Company... So it would follow for heads
Do Aluminum Radiators Need Special Coolant?
The key to maximizing the life of an aluminum radiator is not so much the radiator coolant brand as it is the water type. All coolants sold today will protect aluminum radiators. This wasn’t always the case, however. Traditional copper/brass construction was the primary radiator material for six or seven decades and most coolants sold over the counter at your favorite parts store did not have the proper additive and protection package for aluminum radiators. So, you had to be cognizant of not only your radiator’s build materials, but what radiator coolant you were purchasing. Today, all modern coolant brands are sold with the ability to work in traditional copper/brass construction, aluminum and composite construction, and full aluminum construction with a coolant additive for aluminum radiators.
- First Name: Terry
- Last Name: Woods
Kevin, I think lang's sells the "Water Wetter". Can it be used with antifreeze, since it, by itself won't protect from freezing?Kevin Pharis wrote: ↑Fri May 02, 2025 7:19 pmLooks to be equivalent to Red Line’s Water Wetter, which I have used for a while and am happy. Note the part where it says “does not protect from freezing”, not a problem for me here in Califunny, but might be in other parts of the world
- First Name: Jeffrey
- Last Name: Hausey
The Jaguar guys use modern Green coolant with distilled. They have alot at stake.
- Last Name: Pharis
From the Lucas data sheet;ModelTWoods wrote: ↑Fri May 02, 2025 9:12 pmKevin, I think lang's sells the "Water Wetter". Can it be used with antifreeze, since it, by itself won't protect from freezing?
