Model-A Crankshaft Conversion Machinist
Topic author - Posts: 432
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
I have a customer's project in that has an OHV engine with a Model-A crankshaft conversion that appears to have never been finished on the front end. The Rods & Mains have been completed, but the nose of the crankshaft was not machined for T pulleys, etc. Is there any shops that still do the A cranks conversions that would be willing to finish this crank for us?
- First Name: Henry
- Last Name: Lee
Re: Model-A Crankshaft Conversion Machinist
Brent,
I have done about 40 each of them over the years, just need your crank, gear, woodruff key.
4two38three75seven09
Hank
Hank
- First Name: Brent
- Last Name: Terry
Good enuf. By chance are you coming to Luray where I don't need to crate this thing??
- First Name: Henry
- Last Name: Lee
No as I am writing new chapters in my life.
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
I was just getting ready for a similar question. Brent asked about the T pulley in his first post.
My new C crank block already has the timing gear installed. With no hole for a “T” pulley for a wide belt. My ‘27 runabout with a Rajo and A crank, the pulley is for a V-belt. Do most A crank T engines use a regular A crank pulley like this?
- First Name: Henry
- Last Name: Lee
I always drill mine to accommodate a T pulley. Normally I build my own set of pulleys to either a 4L or 3L size depending on accessories.
Hank
Hank
- First Name: Les
- Last Name: Schubert
To cover up the remains of the woodruff key I use a “SPEEDI SLEEVE”! They are available at better bearing suppliers.
