Hey all,
Hoping someone has an easy way to pull the inner oil seal in the rear end so I can put newer neoprene ones in while I have it apart. Is There a tool that can be purchased/manufactured? Not sure what is in there now cuz' all I can see is the washer but am pretty sure when it was rebuilt last neoprene was just a chemist's dream. Thanks for your ideas, Tried a bent piece of wire but a piece small enough in diameter to go between axle and washer wouldn't seem to do the job.
PS Note to self sleeve pulling tool worth every penny
Easiest way to pull rear axle inner oil seal once bearings and sleeves are out??
Re: Easiest way to pull rear axle inner oil seal once bearings and sleeves are out??
Try a oxy-acetelyne welding rod or any long piece of rod that’s stiff enough and a larger diameter than a piece of wire.
A steel coat hanger wire will work IF you can still find one !
Topic author - Posts: 30
- First Name: Garland E
- Last Name: Pobletts
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Got plenty of old wire hangers but was to big diameter to go between washer and axle or housing
Aaah. Brainstorm. I have an extra piece of brass stock I used to make a new choke pull. Bet that would do it. Will get back to yall.
Got it out. Thanks for help. Just needed to get brain in right mode. Leather and spring so glad I got it out.
You're doing the smart thing. Sometimes the metal parts of those old leather seals will score the axle shaft until it breaks.
