LED Tail Light Conversion 1922 6 volt
Hmorgan
Topic author - Posts: 1
- First Name: Harley
- Last Name: Morgan
- * REQUIRED* Type and Year of Model Ts owned: !922 Touring
Need help finding/ buying best LED lights for tail light conversion for turn, stop . 1922 6 volt 4 door Model T
Moxie26
- Last Name: Jablonski
Re: LED Tail Light Conversion 1922 6 volt
www.logolites.com. Look at the section for brake lights and running lights, ( LED BULBS )....IMO. They are the brightest available.
Moxie26
www.logolites.com. Look at the section for brake lights and running lights, IMO. They are the brightest available..... As far as headlight bulbs, they have the best ones and brightest available and come pre-focused. All you have to do is install and point your headlight buckets as directed.... Plus they're a lot easier on your generator and battery.
big2bird
- First Name: Jeffrey
- Last Name: Hausey
I can appreciate their use on these cars, specially a brake light. However, I think the incandescent lighting is part of the " charm."
Moxie26
......... Geezz,.... Hope you're able to tell that to your relatives after you regain your consciousness after the " charm " accident. Safety First.
If you want safety, drive a Volvo.
Aint nothing safe about driving a T, even with bright lights, turn signals, seat belts, disk brakes & safety glass.
You are foolin yourself.
big2bird
- Last Name: Hausey
I have no fear of death. I'm married.
