Poll:
How low can you run the fuel level in a cylindrical, under-seat, 10-gallon fuel tank?
Fuel Level in Round Tank
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Re: Fuel Level in Round Tank
For an oval tank, empty.
Voice of experience talking….
Depends on driving conditions. The tank is under the seat, so if you are going uphill you will need at least 3 gallons. On level or downhill, you can run until it is empty.
Considering the sediment bulb is 1/2" pipe and normally is protruding up into the tank a bit, until she quits running !
Also depends on whether or not there is any added restriction in the fuel routing, either by design (like an added fuel filter?) or by material failure (kink in the tubing, Shellac build up due to old gasoline, rust flakes, or any of a hundred other things?).
On level roads, any standard model T should be able to run the gasoline tank down to less than a half cup of gasoline left.
I have literally seen a model T touring car stop running, after a long drive, with a gasoline tank so dry that not even a wet spot could be seen on the end of the wooden dip stick.
