two piecce timers
ModelT46
First Name: Darel
Last Name: Leipold
two piecce timers
Post by ModelT46 » Sat May 17, 2025 2:32 pm
picture number one illustrates that the two studs hoilding the cover are alined with the control knob. This is the way all seem to be. picture number two is the timer I bought last month. the two studs holding the cover are off set from the knob by 90 degrees. Has anyone seen or have a two piece timer that is like number two?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: two piecce timers
Post by Kevin Pharis » Sat May 17, 2025 3:55 pm
The embossed lettering in the 2nd photo is much less crisp, possibly a reproduction…? Some of these reproduction parts are older today, than the T’s were when the reproduction parts were made. Getting hard to tell the difference in some cases
Post by RajoRacer » Sat May 17, 2025 7:50 pm
And, they centered "Ford" over the timing rod eye & the oiler cover is on the other side of the eye also !
RGould1910
Last Name: Gould
Post by RGould1910 » Sun May 18, 2025 12:28 am
The races are held to the case by four screws, two of which extend to told the cover on. By changing the position of the long screws you have the correct orientation.
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Mon May 19, 2025 12:48 pm
Thank you for the \help. I will change the poistions of the screws.
