cam bearings
tman12
Topic author - Posts: 179
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
cam bearings
Hi From Iowa: I started to install my new 280 cam & found that I have the wrong frt cam bearing that is not available from main suppliers? At Lincoln last week I was told there may be a new supplier? Des anyone know the scoop & contact? I have also forgotten where to get some red rubber hose for the ac lts? Many Thanks John
Re: cam bearings
Re the front bearing; Have you contacted the suppliers yourself? Try Chaffin's.
tman12
Re: cam bearings
I have contacted all the main suppliers & the man that made the new cam bearings has had problems with the foundery that supplied the blanks & cannot supply at this time. I need to find someone with an extra set or maybe someone else is now making them? HELP John - PS Glen C is the one who told me the sad story!
John bevardos
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Re: cam bearings
Hi John,
I believe that Gene French sells re-babbited bearings. Might try to reach out to him.
John
John
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Kerry
- Last Name: van Ekeren
Re: cam bearings
The longer early bearings can be turned down shorter for the later front bearing, done it many times to have a good fit for shaft end play.
Re: cam bearings
If the usual T suppliers don't have the red rubber hose for your lights, then try Restoration Supply Co. They have 2 grades I believe. One is just like the original stuff, (supposedly), and the other is also pretty nice.
tman12
Re: cam bearings
Many Thanks to all you Great Guys & your Good suggestions - This the Best Group Of People Always willing to Help Us T Lovers With our problems! John
