Can cracked zinc sill plates be repaired?
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Sun May 18, 2025 6:29 pm
I have a set of '26 roadster sill plates that are semi decent except for a couple cracks. Is zinc repairable?
Re: Can cracked zinc sill plates be repaired?
Post by Allan » Sun May 18, 2025 7:30 pm
It will not weld. It won't take solder. You may be is to back it with some shim brass and use epoxy/JB weld to hold the shim in place. Others may have better ideas.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sun May 18, 2025 10:54 pm
While I have never used this product I have know about it for years.
https://www.muggyweld.com/product/super-alloy-1/
It works on Zinc and Pot metal alloys.
But I would use a backer plate to keep cracks away in the future.
No matter what it is, the chrome platers use a filler product to repair the pinholes, cracks, and defects in pot metal before plating.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Mon May 19, 2025 7:54 am
I confirm what Allan said. I tried welding zinc and it did not go so well.
What zinc does well at is forming to a mold, even more so than aluminum. I suppose you could research any safety concerns about re-pouring zinc into a mold that is made from the piece itself.
Vern (Vieux Carre)
Post by Jerry VanOoteghem » Mon May 19, 2025 10:37 am
The sill plate is a stamping, not a casting.
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Mon May 19, 2025 3:06 pm
Vernon, Did you try TIG welding zinc? I have TIG welded it a few times. Tricky but doable. Set my Tig machine to AC like welding aluminum and using a non-ferrous filler rod is key. Preheating slightly seems to allow it to take the weld. A very fine line between a nice weld and total disaster. lol
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Mon May 19, 2025 6:07 pm
I use Muggyweld to repair Winfield cracks. Great stuff. Low temp, like soldering. As for you sill plates, it just depends on the repair.
Post by John kuehn » Tue May 20, 2025 9:15 am
Allan has the simplest repair idea that works. I have a 24 Coupe that has the zinc/aluminum sill plates and using the method that Allan spoke about is the best way for cracks in this application. It will last as long you own and drive your car and beyond.
