Availability of club engine rebuild info
49willard
First Name: Bill
Last Name: Jones
* REQUIRED* Type and Year of Model Ts owned: 1912 Foredoor
Post by 49willard » Sat May 17, 2025 8:22 am
I am new to the Model T community but not to early cars. I am in the process of reassembling my 1912 engine and looking for tips on reassembly for such info as torques, avoiding oil leaks etc. I can't find such info in the club restoration videos or the club utube channel. Am I missing something? I do have the "black book" which is helpful. Materials for sealing joints have changed a lot since the book was written, however, an example is what to use instead of candle wax! There are multiple private videos online but am surprised that the club does not officially cover details of rebuilding the engine proper. Suggestions?
TrentB
First Name: Trent
Last Name: Boggess
Re: Availability of club engine rebuild info
Post by TrentB » Sat May 17, 2025 10:17 am
I am not a professional engine rebuilder, but I was taught how to rebuild Model T engines by a man who was a professional engine rebuilder. The Model T engines he built for himself were used to win the Montana 500 several times, and when he didn’t win, he was always in contention. The techniques he taught me are also explained in the YouTube videos featuring Mike Bender published by the Flatland Ts of Kansas. They can be found by searching for the ModelT-Tips channel. I highly recommend them. Even if you do not go through all the steps described in those videos, they will add significantly to your understanding of how rebuilding a Model T engine and transmission should be done.
Respectfully submitted,
Trent Boggess
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat May 17, 2025 11:35 am
I;m not sure which "black book" that you are referring to, but do you have the engine assembly book, printed by the MTFCA?
Last Name: Hatch
Post by Dan Hatch » Sat May 17, 2025 1:52 pm
Forget FB. Look up threads by Herm and read them. Then use your own judgement.
Lot of information on the old forums.
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Sat May 17, 2025 2:17 pm
Post by RajoRacer » Sat May 17, 2025 2:45 pm
The "Black Book" IS the Model T Bible !
BobUkPipedream
Last Name: Dyer
Post by BobUkPipedream » Sat May 17, 2025 7:40 pm
I second Mike Bender’s videos on YouTube called Model T Tips. It’s what I used.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat May 17, 2025 9:27 pm
Steve, are you referring to the "Ford Service" manual, which Ford sold in hardback form? It has been reprinted with a black cover, but in softback form. Back in the 1960's, when I bought my first softback, it had a green cover.
Post by RajoRacer » Sat May 17, 2025 10:14 pm
Yes, my original "Bible" isn't black either !
49willard
First Name: Bill
Last Name: Jones
Post by 49willard » Sun May 18, 2025 7:33 am
Thanks all for your replies. I am into Mike Benders videos. My bible is the latest soft cover black version.
EliasRay
First Name: Elias
Last Name: Ray
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo
Post by EliasRay » Tue May 20, 2025 9:13 am
Understanding the Model T’s ignition system takes patience—each component plays a role. It’s like assembling research with online assignment expert: each detail matters for the whole to function. Trace your wiring and double-check grounding for consistent spark.
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Tue May 20, 2025 12:01 pm
The MTFCA service manuals are good supplements to the Ford service manual.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Last Name: Hatch
Post by Dan Hatch » Tue May 20, 2025 12:57 pm
Original Service Manuals were Blue Hardback books.
Special ones were Leather bound. Given to special people by Ford.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Tue May 20, 2025 5:26 pm
As I stated in the post titled Instruction book vs. Ford Manual the so called black book isn’t a motors or dykes manual meant to describe how to do a job from start to finish. It’s actually a time study used to give Ford mechanics hints on how to do the jobs faster. That’s why there’s times listed at every job shown. That’s also why some of the explanations given can be a little vague. That’s because the mechanics were familiar with the T. I realize to an extent it’s all that’s available but using it by itself isn’t a good idea if you’re new to T’s.
dykker5502
First Name: Michael
Last Name: Deichmann
Re: Availability of club engine rebuild info - The "bible"
Post by dykker5502 » Wed May 21, 2025 3:29 am
Sorry guys, but the above answers to a newcommer what the "Black Bible" is was quite internal and not very helpful.
The book nicknamed "The Black Bible" is the 2 inch thick book titled "Model T Ford: The Car That Changed the World" by Bruce McAlley:
Den sorte bibel.jpg (35.7 KiB) Viewed 1259 times
Bruce McAlley:
(Taken 15 years ago at Chickasha right after I got my copy signed by Bruse :-) )
Steve Jelf have made a good webpage with what every (new) Model T owner should own:
https://dauntlessgeezer.com/DG80.html
Ford Model T 1914 Touring
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Post by Charlie B in N.J. » Wed May 21, 2025 8:01 am
Nope. Not the one you show. The smaller book that’s usually all black. I believe it says Ford Model T service on the cover though that might be the reprint version. OK maybe I’m wrong but I don’t like to think so. Fuzzy pictures. Vague descriptions and times for each job shown.
jab35
Last Name: Bartsch
Post by jab35 » Wed May 21, 2025 6:30 pm
Ford Service Manual reprint is available from MTFCA Museum:
https://mtfca.square.site/product/model ... se&q=false
It's a reprint and while information is good, pictures are not as crisp as in the original. Vendors offer it for sale as well
Cimorelli has pdf downloads of many ford publications, but not the Service Manual
https://www.cimorelli.com/mtdl/mtdl_year_title_list.htm
