Water Inlet Connection
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Thu May 22, 2025 12:59 pm
Would someone happen to have an early water inlet connection original or reproduction? This is the one with a heavier boss for the bolt holes used 1909 to 1912 supposedly. I was given the name Eric Vandenbeemt as one who reproduces them, but I am unable to locate a contact for him.
Re: Water Inlet Connection
Post by Jerry VanOoteghem » Thu May 22, 2025 1:31 pm
I'm sorry, I can't help you locate one. Not sure where or how you got that name. Be very careful of someone, who knows someone, who has just what you need. Most often a scam...
Good luck in your search!
Last Name: Gregush
Post by Mark Gregush » Thu May 22, 2025 2:55 pm
Check with Langs or KimDobbins. If you haven't, put an ad in the classifieds.
