1926/7 Touring top bow questions.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Tue May 27, 2025 10:02 pm
Well it's time to start looking at the top and boy do I have questions. So here we go
1. Are these the correct top irons for a 1926 Touring car?
I got a work kit from J P Auto Wood.
So why are there no holes in the irons for the rivets that came with the wood kit? Do I need to drill them? Was the original wool just crimped in the irons?
Mopar_man
Last Name: Govoni
Re: 1926/7 Touring top bow questions.
Post by Mopar_man » Tue May 27, 2025 10:09 pm
This clamp was welded on but I've seen them screwed into the wood and it looks like there are holes in the clamp to mount to the wood.
But it does seem to fit the car. Maybe when the wood is placed in the iron the clamp will then lind up on the front wood bow?
Post by Norman Kling » Tue May 27, 2025 10:40 pm
The most important part of the wood installation is the distance between the two clamps on the top of the windshield posts must be exactly the right distance apart. I took a strip of oak veneer and laminated it as I bent it to fit in the curved part of the bows. It will accept tacks works very well on my car.
Post by Jerry VanOoteghem » Wed May 28, 2025 6:30 am
Those bows appear to be kind of bent up. They also seem to have had some questionable past repairs.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Wed May 28, 2025 8:50 am
They looked bent to me as well. When I tried to match the curved wood parts with the bow it looked like they would not fit.
John Codman
Last Name: Codman
Post by John Codman » Wed May 28, 2025 12:57 pm
On my '27 touring the front brackets are bolted and screwed to the windshield post. The rear of the front bars are bolted to the next bar back. All of the other bars are riveted together except where the long rear bar is bolted to the body. The only exception to this is that the second bar back is attached to the rear upright bar with a pin and spring clip.
FWIW - I don't think there is a single factory weld in the car.
Post by Norman Kling » Wed May 28, 2025 1:30 pm
A few important things before you install the top material to the car. There is an inner lining over the bows tacked to the bow under the actual top. The only place the top is attached is to the front bow and the rear bow. Find the center of each bow and the center of the top to align . The straps between the bows will determine how far the back bow is from the front and the strap between the back bow and the top of the body The pads are attached and tacked first then folded over on top and sewed. The rear strap determines the height of the back bow. It should be equal on each side before trimming. The rear curtain in attached to the back bow first and trimmed to fit. Then the top is laid over it on the back and finally the tack strip is attached.
Post by Jerry VanOoteghem » Wed May 28, 2025 1:46 pm
To Mopar_Man/Robert G.,
This is all excellent advice you've been given! However, I'm sorry to say that I would be hesitant to try fitting an expensive top kit to those bows. Do a lot of trying out & inspection before committing the top material to those bows.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Wed May 28, 2025 1:49 pm
The 1926-27 Canadian top is totally different.
That may be a Canadian top.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Wed May 28, 2025 3:26 pm
Interesting, how do you tell if it's a Canadian top?
Mopar_man
Last Name: Govoni
Post by Mopar_man » Wed May 28, 2025 3:28 pm
Thanks Norm! I haven even bought a top yet. My goal was to get the bows fitted first. Thanks, Jerry, for the input.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Thu May 29, 2025 2:08 pm
So how do I tell if it's Canadian?
Mopar_man
Last Name: Govoni
Post by Mopar_man » Mon Jun 02, 2025 11:25 am
Well leave it to Steve Lang to solve the mystery. He noticed that each top looked like it was welded on. Sure enough I looked and he was right. Someone must have cut the tips off and welded C channels on each part. I can not overemphasize the value that Lang's is to the Model T hobby. What great people to work with and what a knowledge base. I just sent an e-mail to Jeff who has a set for sale. This looks like his first time posting so I've got some checking to do.
John Codman
Last Name: Codman
Post by John Codman » Mon Jun 02, 2025 11:38 am
I had made a similar post earlier in this thread.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Mon Jun 02, 2025 11:41 am
Thanks John! I guess I didn't look at the right spot where Steve told bee to look. Thanks for your input!!!
