Stamping code on new head
Bmettli
First Name: Brian
Last Name: Mettling
* REQUIRED* Type and Year of Model Ts owned: 1922 touring, 1933 Dodge
Post by Bmettli » Fri May 30, 2025 8:21 pm
Hi all,
I picked up a horrendous looking head at a swap meet last weekend for a mere $20. It looked fresh from a barnyard and even came with champion ford script plugs still in it. I let it marinate in Trisodium phosphate for the day and scrubbed the snot out of it. It came out a very very nice fresh casting! Very cool.
The marks on it are “11” near the top of the water inlet and stamped “15” on the inside of the water inlet. It is a high head. Any ideas what year? I assume that is Nov 15th?
Bmettli
First Name: Brian
Last Name: Mettling
Re: Stamping code on new head
Post by Bmettli » Fri May 30, 2025 8:26 pm
picture resizing!
Post by DanTreace » Sat May 31, 2025 8:51 am
Typical casting letters or digits on high cylinder heads on the uppersurface over the water outlet are just casting tool identification numerals or letters. Helps to identify the casting tooling for control purpose.
Tiny mechanical stamped numerals on milled surfaces are always inspector's stamps, again for quality control.
Here are examples. They haven't any use in telling the age or time of fabrication.
IMG_8920 (520x390).jpg (103.05 KiB) Viewed 897 times
IMG_8919 (520x390).jpg (98.2 KiB) Viewed 897 times
This one casting letter is a fun one, a "Z".....but this is a factory Ford cast iron high head. Can confuse some who might think may be the Modern Alum Hi-Compression Zajicek made , Z Head, which is marked this same way.
IMG_1139 (500x367).jpg (87.18 KiB) Viewed 897 times
Bmettli
First Name: Brian
Last Name: Mettling
Post by Bmettli » Sat May 31, 2025 11:11 am
Thanks Dan!
