Does the top attach to the windshield?
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Tue Jun 03, 2025 11:29 pm
There are a couple flaps at the front of my top that look like they should attach somehow to the top of the windshield, but I don’t see how. When I drive with the top up, the wind lifts the top a bit and the wind blows over windshield.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Does the top attach to the windshield?
Post by Dan McEachern » Tue Jun 03, 2025 11:42 pm
What year or style of windshield? it makes a difference. Top with straps to the windshield or top w/clamps to the windshield posts, or?
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Tue Jun 03, 2025 11:47 pm
Hey Dan. It’s a 22 runabout. Here are a couple of shots of it. You can see the flaps on the top. Looking at it, it looks like it’s coming down enough in front. Maybe the rear straps are too tight.
Last edited by Reno Speedster on Wed Jun 04, 2025 12:34 am, edited 1 time in total.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed Jun 04, 2025 12:14 am
The flap goes over the windshield.
The snaps at the corners are for your side curtains.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Wed Jun 04, 2025 1:36 am
Does it look like the top is in the right place in relation to the windshield?
Dan McEachern
First Name: DAN
Post by Dan McEachern » Wed Jun 04, 2025 3:25 am
The front of the top appears to be about 1½" too high. The front flap should extend over the front of the upper windshield frame and the rear flap should hang behind the frame. This will keep air from coming over the top frame. Your rear curtain may have shrunk a bit making it difficult to get the front of the top lower, or yes you could loosen the rear straps. Get the car in the sun and let the fabric warm up so it can stretch a bit.
Last Name: Hatch
Post by Dan Hatch » Wed Jun 04, 2025 7:59 am
Is the angle right on this arm? Or is the way picture is taken?
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Jun 04, 2025 1:25 pm
The top needs to rock forward so the front bow is lower and closer to the windshield. Check to see if the center sockets are vertical. You may not achieve perfection with your adjustments but you can improve things.
I like the suggestion of placing the car in the hot sun first.
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Jun 04, 2025 1:28 pm
I dont see another hole in your top strap. You may have to punch another after settling on the position. Go slow and recheck.
Post by Norman Kling » Wed Jun 04, 2025 3:04 pm
The rear straps might be too short. Unfortunately, after they are placed and the rear curtain has been trimmed, there's little you can do about it unless you replace the rear curtain.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sat Jun 07, 2025 9:08 pm
I loosened the rear straps and punched another hole on the windshield straps. When it was in the right place I used a heat gun to gently warm up the back panel of the top. Sadly, we are short of sunny days up here this summer. Looks like it’s in about the right place now.
Post by Original Smith » Sat Jun 07, 2025 11:34 pm
It appears to me your leather straps are back too far. I agree with Dan.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Jun 08, 2025 12:41 am
Which Dan and about what? First I heard about the straps being in the wrong place.
Post by Allan » Sun Jun 08, 2025 12:56 am
The front straps need to hold the top down over the windscreen and keep it forward, so they need to be angled. Over time, the top and rear curtain will tend to shrink, causing the fit problems as seen here. Heat and constant pressure are your friends in stretching the fabric and then holding it in place when not in use.
John Codman
Last Name: Codman
Post by John Codman » Sun Jun 08, 2025 2:19 pm
My guess is that you are right about the rear straps. My T is a '27 that has clamps to the windshield posts, but the flap is clearly a seal between the top and the windshield. If any significant amount of air can flow between the top and the windshield, bad things can happen.
