Have You Ever Seen Anything Like This.
Mighty1924
First Name: Rick
Last Name: Shaw
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
Post by Mighty1924 » Thu Jun 12, 2025 8:59 am
A friend brought me pictures of this and wondered if I knew what it was. My first thought was a Urn. Thought I would post here for those with greater knowledge to help.
ANY IDEAS??
Thanks Rick S.
Re: Have You Ever Seen Anything Like This.
Post by TXGOAT2 » Thu Jun 12, 2025 10:52 am
I've never seen anything like it. My guess is it's a container to store calcium carbide for use in headlights, a miner's lamp, or even home lighting. Carbide has to be stored in an air and moisture tight container or it will deteriorate.
Post by TRDxB2 » Thu Jun 12, 2025 10:59 am
Hard to tell how big it is. Dimensions would help
Is that a cork on top or brass plug?
Since it says "Complements" on the top & looks like an URN... Might someone's ashes be inside = Funerary urn
Could be a trophy too
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Thu Jun 12, 2025 11:11 am
It it a automotive lamp.
https://www.ebay.com/itm/297247870409
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Thu Jun 12, 2025 11:16 am
Amazingly, your friend brought you pictures that were used on that eBay auction but didn’t show you all of them which would have given you all the answers.
William L Vanderburg
1922 Center Door Sedan
Post by Jerry VanOoteghem » Thu Jun 12, 2025 2:45 pm
So, what are all the answers? It's not a lamp in any traditional sense. It has no burner or gas jet, nor does it have a place for one. It has no obvious way to mount it. It also says "Compliments of Corcoran Victor", as if it's some sort of commemorative or promotional item. What lamp has anyone seen that stated "Compliments of ...."?
Post by TXGOAT2 » Thu Jun 12, 2025 9:22 pm
The Leg Lamp?
Robert Kiefaber
First Name: Bob
Last Name: Kiefaber
* REQUIRED* Type and Year of Model Ts owned: 1906 model F, 1907 model R, 1915 centerdoor sedan, 1921 centerdoor sedan
Post by Robert Kiefaber » Thu Jun 12, 2025 11:18 pm
Maybe a wick burner screws in where the cork is.
Post by Mark Gregush » Fri Jun 13, 2025 2:05 pm
Ash tray maybe?
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Fri Jun 13, 2025 2:39 pm
Is the top on that a door/lens from a ‘15 sidelight?
Last Name: Hjortnaes
Post by DHort » Fri Jun 13, 2025 10:16 pm
Looks like the size of a coffee cup with a cork in the bottom. If smaller it could be a salt shaker.
Like stated previously, no dimensions????
Mighty1924
First Name: Rick
Last Name: Shaw
Post by Mighty1924 » Sat Jun 14, 2025 8:59 am
Thank you everyone for your thoughts as what this might be
I'll forward a link to my friend so he can see your ideas and thoughts
Thanks again
Rick.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Jun 14, 2025 2:24 pm
It’s a complimentary desktop ash tray from Victor.
