Mounting the low firewall in place of wood firewall.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Sat Jun 14, 2025 6:08 pm
when replacing the 17-22 wood fire wall with the low steel replacement fire wall are spacer washers needed betwern the frame mounting brackets and the metal firewall? If so what are its dimensions. Thanks for your support. Jp
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Mounting the low firewall in place of wood firewall.
Post by Humblej » Sat Jun 14, 2025 6:18 pm
Steel firewall uses different brackets.
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Sat Jun 14, 2025 6:47 pm
Humble. You are referring the ones with the square holes instead of round. Yes I know of that change. Thank you.
Post by RajoRacer » Sat Jun 14, 2025 7:18 pm
Jack - somewhere, I believe in the Service Bulletins there was an article referring that - Ford suggested using the outer radiator thimble as spacers (4).
First Name: john
Last Name: karvaly
Post by speedytinc » Sat Jun 14, 2025 7:52 pm
As luck would have it, I have both an early 23(wood FW) & a 23 with steel firewall.
The difference is 1/2"
I like the idea of using the top radiator mount caps over a couple of wood spacers.
Post by DanTreace » Sat Jun 14, 2025 8:49 pm
Here is info on those spacers.
Post by Allan » Sat Jun 14, 2025 10:41 pm
If staying with the wood firewall to frame brackets all that is needed is two wooden spacers to make up the difference in thickness of the two firewalls.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Sat Jun 14, 2025 11:18 pm
As has been stated it was common practice to use the upper radiator mount thimble as a spacer, with 4 being needed. I guess you could grind the open end of the 1/2 inch thimble down the 1/16 of a inch to get to 7/16 of a inch if you so desired, but generally there is enough play in frame to steel firewall mount to not make that necessary.
Post by Allan » Sun Jun 15, 2025 7:52 pm
If wood wood be no good, perhaps we should be replacing all the wooden spacers under all the metal running boards with radiator thimbles.
In the firewall application I know which solution wood look less like an interim patch-up job.
Allan from down under, where wood is good.
Post by Allan » Mon Jun 16, 2025 4:16 am
In Trent Boggess's article posted by Dan, he stated...
".... the Ford engineers designed a round 7/16 inch spacer that WOOD go between the new steel dash and the mounting points on the earlier dash to frame brackets."
Trent's subconscious led him to the better solution than that of the engineers. ;) ;)
First Name: Austin
Last Name: Farmer
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by 1925 Touring » Mon Jun 16, 2025 1:38 pm
