1913 KW Switch
1913 KW Switch
Post by Original Smith » Sat Jun 14, 2025 7:03 pm
Should you be working on an original switch, do not assume the 6-32 screws that hold the brass plate on are the correct length. Try one gently to make sure it will work properly. I had a NOS switch that I decided to upgrade with a nicer looking plate. The screws were a tad too long, and pulled out the inserts. with messed up the whole switch. Don't do that without trying them beforehand.
