Did this carbide generator blow up?
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Fri Jun 20, 2025 8:46 am
I recently came across these remnants of a carbide generator.
It is a side mount type of generator. Holy cow, what happened to it?
Is it just showing the effects of age and brass cracking from the spinning process? I have seen other pieces of brass get this way, but not to the extent this one has suffered. It looks shredded.
First Name: Keith
Last Name: Townsend
Re: Did this carbide generator blow up?
Post by KWTownsend » Fri Jun 20, 2025 10:11 am
Herb-
I believe that is the effect of 100+ year old spun brass that has been exposed to the elements.
The upper chamber is the water reservoir. The lower chamber would have had the acetylene gas.
Keith
Greg Griffin
First Name: Greg
Last Name: Griffin
* REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
Post by Greg Griffin » Fri Jun 20, 2025 2:53 pm
Notice the presence of a valve where the hose would connect to the generator. I suspect that the generator was "shut off" by stopping the water drip and immediately closing the valve, which would bottle-up the gas still being generated by the still-wet carbide. The generator probably burst, not exploded.
Doesn't explain burst top tank, though.
Post by Jerry VanOoteghem » Fri Jun 20, 2025 4:28 pm
It's all due to stress corrosion cracking in cold worked brass.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Jun 20, 2025 8:30 pm
I don't know what brand of acetylene generator is pictured, but on the E&J generator for my 1911, when the water valve is turned to the "off" position, it opens a port to vent the acetylene in the bottom of the tank to the outside.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Fri Jun 20, 2025 10:13 pm
Herb I think you have what is left of an early Jno Brown generator judging by the wing nut locks.
49willard
First Name: Bill
Last Name: Jones
* REQUIRED* Type and Year of Model Ts owned: 1912 Foredoor
Post by 49willard » Sun Jun 22, 2025 12:57 pm
Herb-
Keith
I would go with Keith's response. Too little cold working in spun brass dents easily. Too much cold working in spun brass invites significant cracking with time. For my 2 cylinder Buick I managed to buy new spinnings a number of years ago but needed the hardware (They are Gray and Davis bullet lights). I purchased a set of lights properly represented as only good for hardware. When I opened the shipped lights in a box I just laughed and exclaimed that they looked like cherry bombs had been set off inside each light looking much like the pictured generator.
