Flywheel ring gear heads up
Topic author - Posts: 5230
- Last Name: Hatch
I am in the process of rebuilding some flywheels. Installing new ring gears, like I have done many times before.
Tried to install a new brass screw in a hole about halfway through and would not start. Turns out some chinaman missed tapping it. This is second one I have seen in a couple years. Not sure of the age of this ring gears, but watch out guys.
- First Name: Henry
- Last Name: Lee
Re: Flywheel ring gear heads up
Sent the memo to my cousin One Hung Low and he is on it! He says....,"Capitalist B@sT@rds want everything perfect".
- Last Name: Hatch
I should have known!
Is the area of the threads to hard to re-tap?
I ask because I have one with the wrong bolt pattern.
- First Name: DAN
- Last Name: MCEACHERN
Be aware there are ring gears out there wit the original #14-24 threads and also i believe 1/4-24 threads. This came about around 10 years ago due to some supplier mix up so make sure you use the correct screws. Snyders has screws with both threads available in their catalog as do most other parts suppliers. The ring gears are soft enough to retap or redrill if you need to.
- Last Name: Hatch
All the new I have run into are 1/4” x24.
- First Name: Terry
- Last Name: Woods
Won Hung Low also said, " Not to mention your Supreme Leader is trying to screw us China men with high tariffs."Henry K. Lee wrote: ↑Mon Jun 23, 2025 6:00 pmSent the memo to my cousin One Hung Low and he is on it! He says....,"Capitalist B@sT@rds want everything perfect".
- First Name: David
- Last Name: Kahle
- * REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
He is the brother in law of the QC manager, Som Ting Wong.
