What is this thing?
rlaplander
Last Name: Laplander
* REQUIRED* Type and Year of Model Ts owned: 1926 roadster
What is this thing?
Post by rlaplander » Mon Jun 23, 2025 7:21 pm
I’m working on a 1926 Roadster I just got, and the guy gave me an extra axle assembly.
On the end of one of the spindles, sticking out ahead of the axle is this thing. Anyone know what the heck it is?
Scott C.
Last Name: Clements
Re: What is this thing?
Post by Scott C. » Mon Jun 23, 2025 7:33 pm
It is a speedometer drive mount. It treads onto the end of steering arm.
rlaplander
Post by rlaplander » Mon Jun 23, 2025 8:47 pm
Think anyone would want it? I have no use for it and if someone else does they could have it.
Post by Allan » Mon Jun 23, 2025 11:35 pm
It is useable for someone. Just list it in the classifieds. Use one of the vendors catalogs for a likely price, as some of them are reproduced. The one you have with the taper on the end takes a bracket arm which binds on the taper. The arm is held on with a bolt threaded on to the end. Another type sees a different arm clamped around the extended nut.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Thu Jun 26, 2025 10:28 am
here a gear mounted.
Andre
Belgium
Post by Original Smith » Thu Jun 26, 2025 11:18 am
I have that exact part on my 1925. It's a Stewart part.
Post by Allan » Sat Jun 28, 2025 7:26 pm
Andre's bracket is the alternative to yours. Note his has no threaded hole and taper on the end. His bracket clamps around the extended nut.
