5 to 1 steering
Last Name: Juhl
5 to 1 steering
Post by Oldav8tor » Fri Jun 27, 2025 7:41 pm
I'm sure this question has been asked many times before, thanks for your patience. My friend has a 1922 Model T. Is it possible to convert the steering to 5-1? If so, what must be changed?
First Name: john
Last Name: karvaly
Re: 5 to 1 steering
Post by speedytinc » Fri Jun 27, 2025 7:56 pm
Steering shaft, center gear shaft & 3 gears. The best way is to find a complete late unit & remove those parts.
Re: 5 to 1 steering
Post by Jerry VanOoteghem » Fri Jun 27, 2025 8:48 pm
Tim,
Even by swapping out the parts described above, there can still be some binding issues when changing over to 5:1. I believe the issue is that the 4:1 gears are made with a different pressure angle than the 5:1 gears. Gears produced with different pressure angles are not meant to work with one another. While you're changing the sun & planet gears, your are still using the internal gear in the gearbox. Still, it's not always a problem, since many gearbox internal gears are somewhat worn by now, creating some additional clearances to alleviate binding. In the case of my Speedster, changing to 5:1 went well.
Last Name: Hatch
Re: 5 to 1 steering
Post by Dan Hatch » Fri Jun 27, 2025 9:20 pm
I think there is a Service Bulletin that covers this.
Re: 5 to 1 steering
Post by DanTreace » Fri Jun 27, 2025 9:40 pm
Here's the info:
The important item is the steering post, that has to be the late 5:1 post, as the pinion pins are different center lines than the 4:1 post, that will make it impossible to fit 5:1 gear set.
IMG_2412 (700x593) (600x508) (550x466).jpg (151.32 KiB) Viewed 718 times
mbowen
First Name: Miles
Last Name: Bowen
Re: 5 to 1 steering
Post by mbowen » Sat Jun 28, 2025 7:36 am
I’ve also read that the grooves in the gearcase to limit shaft rotation are different between the 4:1 and 5:1 units.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Harvey Bergstrom
First Name: Harvey
Last Name: Bergstrom
Re: 5 to 1 steering
Post by Harvey Bergstrom » Sat Jun 28, 2025 8:44 am
I upgraded my ‘24 Touring to the 5:1 gear ratio & as previously stated, you need to replace all the old 4:1 system to make it work properly. My Touring steers beautifully & I absolutely enjoy the steering now! Good luck & enjoy your T!
Last Name: Hatch
Re: 5 to 1 steering
Post by Dan Hatch » Sat Jun 28, 2025 9:03 am
It all depends on the wear in the 4 to 1 gear case. The more wear the better the chance of 5 to 1 gears fitting. Dan
NoelChico
First Name: Noel
Last Name: Chicoine
Re: 5 to 1 steering
Post by NoelChico » Sat Jun 28, 2025 10:18 am
I swapped the entire steering column on my "23 for a 26 column. I think that's the easiest way. There are several columns on the parts for sale site presently.
Russ T Fender
First Name: Val
Last Name: Soupios
Re: 5 to 1 steering
Post by Russ T Fender » Sat Jun 28, 2025 1:00 pm
I worked the new gears in the old case on my ‘14 with green timesaver. It took a while but the results were worth it.
Re: 5 to 1 steering
Post by TRDxB2 » Sat Jun 28, 2025 2:43 pm
Another difference not mentioned because of tire width.
late and early case with groove .jpg (28.89 KiB) Viewed 539 times
Re: 5 to 1 steering
Post by Jerry VanOoteghem » Sat Jun 28, 2025 7:44 pm
It was mentioned, but thanks for the pictures.
Last Name: Tannehill
Re: 5 to 1 steering
Post by JTT3 » Sat Jun 28, 2025 11:51 pm
For me the easiest way to work the 5/1 gears in an early riveted brass head is by doing one of the triple gears at a time using yellow time saver your mileage may very. Takes about 2 hours doing it that way. Best John
First Name: Henry
Last Name: Lee
Re: 5 to 1 steering
Post by Henry K. Lee » Sun Jun 29, 2025 4:35 pm
Why not just remove the steering column, get a donor upper gear case with the original 5 to 1 and do it correctly. Your spark rod and throttle rods are probably worn out and replace them too!
